Twitch de la Brat
    6
Everything posted by Twitch de la Brat
  1. I must be blind or stupid, but I can't find my fuel pump relay. Nor can I find the location listed anywhere on here or the Internet. So, I turn to my fellow Subaruians, anyone know where the bastard's hiding? I need to replace him. Also, the 85/86 XT's are unique in their wiring setups, at least according to my craptastic Chilton manual. And even more-so because it's a bloody turbo. So, anyone have any ideas? Every location has been checked aside from putting the car on a lift and scouring the underside. Also, it specifies the relay sits between the EGR valve and the fuel pump in the wiring harness. This may or may not help depending on if anyone's torn down a harness or not. Twitch
  2. There's clip on the end of the shaft that the pedal rides on. You'll need some really good pliers to get it off. There are some plastic bushings that ride on the shaft, make sure you don't lose those when you pull the pedal off. Once the pedal is off, you should have enough movement and slack to get the end of the cable off and out. It's the same attachment style as your throttle cable. Rotate until the cable slips free and you can finagle the end out. Twitch
  3. That it does. I'm sure I can hunt down an XT6 in the junkyard, and I usually order the XT6 clutch when I do the 5sp swap anyway to maximize biting force without compromising drivability and costing an exorbitant amount. Twitch
  4. Thought so. I'll be doing that when I swap in the 5sp d/r. Any recommendations on how much to take off with a high-comp, torque build EA81? I'll be running an EA82 flywheel. Twitch
  5. Necrobump. Any new on this? I need to acquire a lighter flywheel for my hi-comp EA81. I can shift the sucker faster than the engine drops revs (even with the stock 4sp) and it revs plenty quick right now, but losing revs is a pain. Takes way too long to return to idle speed. Twitch
  6. Soooo my temp fix (ignoring it) on my tranny mount ended up eating an axle. Oh well. I'll just yank one off the BRAT and drop it in, as soon as I dig the BRAT out of the snowbank... Also, we finally have aftermarket transmission mounts! So $30 and a few bucks shipping from amazon and I'll have 2 fresh transmission mounts. Hell, I'll just order something for $5 and skip the shipping Anyway, thats the major updates. Still slowly sanding off the old paint with wind, rain, snow and the occasional brushing against with clothing Twitch
  7. Don't be too surprised if you have to get a new intake. The bolt in mine was so hard it dulled brand new carbide bits (albeit harbor freight) Twitch
  8. I've got a second Gen for sale... Also, I was just informed of a first gen for sale at a local lot in Hayden (North of Coeur d'Alene). To OP, congrats on the new acquisition! Glad you found us and that we could help. Don't forget to hit up the 1st Gen forum for any goodies or advice you may need. Twitch
  9. Your car has a carburetor, and therefore no MAF Carbs usually don't care what filter they have as long as it flows enough air. I had (have) a K&N on my BRAT and I didn't notice any real pickup in power, but I did notice it's resiliency to oil coming through the PCV system. If you have higher mileage, a K&N may be worth it in the fact that it doesn't sog up with oil like a paper filter does. I may have the part number laying around somewhere for that if you'd like the exact number Twitch
  10. Apply said tension, apply penetrating oil, heat it with a torch, then find a brave (stupid) soul to whack it with a BFH (Big F-ing Hammer). Just make sure they don't crack the cup. Twitch
  11. Tires are good, depending on brand of course, but the guy probably paid out the nose for them. If he gave you the receipts with them, you can go to an Les Schwab and they'll rotate them and do free flat repairs. But otherwise the place is a massive money sucking hole. Twitch PS: For example, they have a separate charge for mounting and balancing. It's like $12 to mount and $8 to balance a tire. Last time I had them put on a set of tires I walked out with over an $80 bill for 4 tires, mounted and balanced.
  12. I just used the lookup on an auto parts store's website to find the bulb number required and then searched it on amazon. EG: "192 LED", and it brought up a good number of listings. Twitch PS: 192 bulbs are the bulbs for EA81 dash/indicator lights and front markers
  13. I just used the lookup on an auto parts store's website to find the bulb number required and then searched it on amazon. EG: "192 LED", and it brought up a good number of listings. Twitch PS: 192 bulbs are the bulbs for EA81 dash/indicator lights and front markers
  14. As has been mentioned, have you checked your alternator output? A random voltage spike can fry a lot of different things. Also, have you checked the backside of the fuse box for corrosion/broken/frayed wires? Twitch
  15. Nice job. I'm considering doing the same for all of my dash lights, but the LED replacements are so cheap and easy to get... Twitch
  16. Duty C Solenoid has failed. It is the solenoid that locks up the AWD in the transmission. You need to put in the FWD fuse unless it's really slick outside and you need the extra traction. What is happening is the center clutch pack is locked and when you turn, the tires are trying to turn at different speeds, but the clutch pack isn't allowing that to happen. So it starts to bind up the drivetrain and slows down the car. The easiest "remedy" is to plug in a 15 amp fuse into the FWD fuse holder on the front passenger side strut tower. The proper remedy is to replace the duty C solenoid and the clutch packs in the tailshaft of the transmission. Further details awaiting your response. Twitch
  17. Did you change the wheels or tires on it? Twitch
  18. I know I have been quite busy as of late, so prime photography times have been elusive. But its not pretty. Twitch
  19. Been seeing a lot of failing alternators recently myself at NAPA. Starting to wonder if our rebuilder got a bad batch of components. Wonder if Delco is using the same suppliers? I haven't checked any other retailers to see if they've had a lot of returning parts yet or not. As for my 83 Blu Bomb, got him aligned and some fresh inner tie rods put on. Just so happens I got the last 2 inner tie rods left in at least a 3 state area. So apologies to any who may be looking acquire EA81 inner tie rods in the northwest. Only other one I could find was in Alaska Also swapped my good tires from the XT to the wagon since the XT is still down with an unreliable fuel pump. And still really don't want to have to buy one. Twitch PS: Finally got another car home, and now realize I just want it gone, so if anyone is interested in a beater BRAT (and I mean beater body-wise at this point), let me know. PM or e-mail would be best. Btwitchy102 at geemale dot coma
  20. You working with Brown in Spokane? Or someone else? Also, don't be afraid to call up your local napa to get bearing numbers off of specs, because we have access to thousands of bearing numbers. This is of course dependent upon if your local store still has their bearing spec book. If all else fails, get a micrometer/calipers and call the Rathdrum store, (208) 687-5500. I work there and that book is very well known and used. If you're hoping to get me, I work Mondays and Fridays only right now; otherwise everyone else is pretty (or very in some cases) knowledgeable. Twitch
  21. Considering the risk and cost of getting new bearings vs rebuilding the old ones, I'd say this may be an exercise in futility, but, to humor you, I'll try to exact some more details. You'd need to match your bearings exactly. And by exactly, I mean within a ten-thousandths of an inch. Type of bearing is obviously easy, but bearing speed rating needs to be matched as well. Also, depth alignment and getting the bearing to seat in properly could be a challenge. If you could set up a jig that seats the bearing flat and at the right depth, you might be on to something for a quick turnaround for customers/yourself. You know how to work wood? Twitch
  22. Can't say for OEM, but Napa has some universal fitments that match spec for $50-80 online. You could probably cross their number with something on rockauto and get it even cheaper. Twitch
  23. Years and years and years. Their death seems to be random and, unfortunately, untimely. I've only ever replaced one carbed EA fuel pump and that was because the previous owner had removed it Twitch
