5
Everything posted by Twitch de la Brat
I'm sure some of you have seen my thread about needing a RHD vehicle or parts. Well, I found a website that imports vehicles. JDM prices FTW!!! Anywho, has anyone tried to import a vehicle lately? I've been researching and am having a hell of a time finding any info on bringing car up to EPA spec. I think that's my last hurdle, please correct me if I'm wrong. I've got links to importing companies, shipping companies, and ports that handle vehicles. Without bringing it up to EPA spec, its currently going to cost me about $3k to buy, import, and ship/drive the car to my house. Any other suggestions? Twitch
What to get on my License plate?
Twitch de la Brat replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
True that, but he's gotta know anybody who knows him from AutoX or of him from whatever Forums he's on will sooooo want to race. I know I would, in my stock BRAT Twitch -
EVOEATR GRNYCAR FAST GL SUBROKT 1FASTGL But SUBRDAV I think is your best bet. Twitch -
96 VW Jetta III
Twitch de la Brat replied to Twitch de la Brat's topic in Non Soob Cars and Bikes Discussion
Well, he got his sights on a gti tranny, so hopefully he can buy it and get it installed soon. I'm getting kinda sick of playing chauffeur... Not to mention I was a clod and smoked the clutch in my BRAT But that's a whole 'nother topic. Twitch -
Holy subaru god's
Twitch de la Brat replied to pinksock's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I love that color actually. Its a nice shade of Brown. Congratulations on getting it. $2700 is a pretty good price, esp considering you have practically every receipt since the car was bought. I highly recommend you keep exactly as it is. It may not be too valuable right now, but in 10 years or so its probably gonna be a valuable as an EA81 turbo coupe. Oh, and do the same thing as that little old lady, keep every receipt, do everything at the dealer, or reputable mechanic, and that baby will be worth a mint in the future. I wouldn't care if its an EA82T. If anything has been maintained like that, I would buy it. Even if its a Maserati Bi-Turbo And thank you Qman, I hate to see a good wagon thread get trashed with bad commentary. Twitch -
Ok, if he's a certified Subaru mechanic I would trust this info. I wasn't sure if it was a viscous center diff or a clutch pack. If he says its a clutch pack, then it may be your clutch plates or the duty C solenoid causing the issue. Its not too uncommon to see the clutch plates fail after 150k-200k mi, nor is it uncommon to see the duty C solenoid bite the dust either. So if you're going to do it your self, pull the tailshaft housing and inspect the plates for excessive wear. If they appear to be fine, I would definitely check out the duty C solenoid. But if you're having a mechanic do it, I HIGHLY recommend taking it to a certified Subaru mechanic or at least a Subaru specific mechanic. Twitch
Are all of your tires the same size and tread wear? If you're running odd sized tires, your viscous coupler would be working while you driving normally. After a fair amount of driving with odd sized tires, the coupler will get hot and lock up the center diff. That's the reason the car will stall out on low speed turns. The center diff isn't allowing the tires to rotate at different speeds. Twitch
Now, does it only slow down at slow speeds, or at all speeds? If it seems to dog at all speeds, check your tire pressures all the way around first. If any are low, then air them up appropriately, I believe Subaru recommends 27-32 psi per tire. Then do donuts on gravel, as you can listen and see if you have any wheel not slipping enough. If you do have an issue with a tire not slipping enough, it could be torque bind. I'm not sure, but I believe those transmissions have a clutch pack that runs the AWD. I'll try to find a wiring diagram to confirm this. If it does have a clutch pack that runs the center diff, get ready to order a duty C solenoid or clutch packs. They should run somewhere between $100-$150 from the dealer, or you may get lucky and find it at an aftermarket dealer for less. But if its like the early EJ 5spd with the viscous center diff, I would be looking for a used center diff, as they rarely fail. Junkyards are the best option for this, either a U-pull-it or a They-pull-it, just have to make sure they have what you need. I'm not sure if you can swap a viscous center diff into a clutch pack style transmission. It would be a good time to investigate, as you have to pull the tail housing off the transmission anyway, if it is a bad center diff. Twitch
Now are you replacing the engine or the transmission? If you're replacing the transmission, then you'll need new axles, as the FWD 93 Impreza axles are 23 spline rather than 25 like the majority of the EJ. As for the engine, I believe you can use everything that's already on your current engine and be just fine. Twitch
BRAT Meet **post your photos**
Twitch de la Brat replied to Fenix747's topic in Meet n' Greet. Your USMB Welcome Center
Well, unfortunately I'm unable to offload the pictures off my phone right now (piece of crap) anyway, I had a great time, made it back just fine Almost got zinged with a ticket on way home Thank goodness the cop was in a decent mood :-\ Those guys were out in FORCE this weekend. Saw one going after another guy going the opposite direction. I had a great time! But I probably won't be going over a day early again. It gets kinda lonely out there in the boonies... Overall I had a great time. Maybe next time I won't be so broke :-\ and neither will my BRAT Thanks again to everybody who helped! And I hope to be there next year! Maybe on a less policed weekend... Twitch -
Last post before the trip, hope nobody needed to get a hold of me :-\ See Y'all there, rain or shine, I will be there. Twitch -
Wow, this is just after Brian joined... He got down to business quick As GD said, good job for searching, but check the dates of the posts before you reply... Mostly so you don't sound like an idiot Twitch PS: By the way, how did that go?
To answer your first question, you can clean up threads with a slightly different tap, as long as they are just starting threads and not the whole thing. Such as you can use a 12x1.5 tap to clean up some 12x1.25 threads. And if you wish to get just a straight 12x1.25 tap, good luck. I've tried to find one for myself, and they are next to impossible to get. As for your second question, if you are going to drill it to 1/2 in and re-tap, use a fine threaded tap. 12x1.25 is considered extra fine, so a fine thread standard should be ok. Twitch
Build Thread for my 1978 Wagon...
Twitch de la Brat replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
I like the electrical channel across the engine bay Are you gonna take care of that rust? Looks pretty nasty... Twitch -
rear axle removal
Twitch de la Brat replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never mind, I got it with 15 minutes of heat and alternating bashing with a BFH and a steel rod. I coated it in bearing grease before reinstalling it, to reduce the chance of sticking and rust formation. Thanks for the info in the thread though Twitch PS: Its just about ready to go, I've just got to finish bolting it together -
So? Who's going to be up on Friday? I'll be heading up early Friday morning, as in, I'll be going through Spokane at 8 or 9 in the morning. Anybody wanna convoy? (And yes, I will play that song ) Twitch
