Everything posted by Twitch de la Brat
Poll: Favorite Old Gen Model
And that's the other poll I created, its favorite generations, not favorite older generation model. The poll for favorite Older generation model is located in post #1. The very first sentence, in white. Twitch
If you look at specs, the XT6 is a whole different animal. It has a specialized power steering package, its the only EA to have a 5 lug bolt pattern, the ER27 is subaru's first H6 engine, and I could go on, and on... Twitch
Losing a fuse?
I'm thinking that, but the problem is intermittent. It may be from the new ignition that was installed sometime in the past. It was dealer installed, or at least by someone who knew what they were doing, because everything looks stock. But do you know if anything else would be affected by the "On" circuit shorting out? Twitch
Da Poll... All I ask is that you reply to let me know who, and how many people voted. Twitch PS: Although McBrat's BRAT is the pic I used, please don't be biased because of it, and there is a reason I didn't include an option for it. (I could only put 9 answers in! ) The picture used is property of McBrat and was used without his permission If you wish for me to remove it, I will, Mick
Losing a fuse?
I would be out there testing it and playing with it, but I had to take my bro in law to work. I know there is no spark, I have tested that using my radiator fan. Idk if it has fuel, I have yet to check that. I believe that it does have fuel, or it should, because the fuel pump is run directly off the alt (stock wiring pattern) It does turn over, so the wiring between the battery and the starter is still good. Twitch PS: I have yet to throw any parts at this thing, I like to diagnose before I spend any money
Losing a fuse?
Already done. And the continuity of the fusible links has been tested too. Any other ideas? Twitch
Wedding --Mine
x100 CONGRATULATIONS!!!! Get ready to make sacrifices... :-p Twitch
Losing a fuse?
Check, check and check :-\ I think just to appease the electrial gods, I'll be replacing all of my old ground wires and seeing if that does anything to the problem. I'm pretty sure that it is something between the engine power and the main fuse box, but where? If I start the car and let it warm up then pull the main fuse the car will continue to run. I believe this is normal because its a standard carb engine, correct? If not that may point to my problem. Another thing I'm looking at is the aluminum wiring in these things. That stuff is notorious for causing shorts because of the thermal expansion properties it has. Twitch
Losing a fuse?
Well, it failed about 2 weeks ago. SO now after buying the "nightwagon" (87 Gl carb w/5sp d/r) the BRAT sits. I took it for a quick jaunt (500ft or so) and promptly destroyed a CV boot. SO now its REALLY parked. I turned the key on, not the engine, and played with electricals. You know, lights, wipers, fan, turn signal, anything to rile the electrical problem. Well, one by one, nothing worked, until I kicked on my aftermarket fogs. Killed it quicker than a rattler on a mouse. Then it wouldn't start. So any other idears? Cuz I'm lost. I've checked all my fusible links, the plugs between the fusible links and the fuse block, nothing. And this whole time my accesories stay on. But no spark to the ignition coil, no headlights and no dash lights. Twitch
Attn Bobaru: The blue car lives on!!!
Oooooo, pretty... Twitch And btw, in the window of the house, is that a rat or a dog? It looks kinda like a chihuahua, but I'm not sure...
Need help finding stupid little Brat specific plastic thingy...
I'm looking for the same stupid things!!! I'm watching this to see if it gets anywhere... Twitch PS: I think you may want try automotive stores, I've seen lots of miscellaneous crap in my local Schucks/Oreilly's accessories section
99 Saturn SL1
Wow. This board has officially hit the absolutely amazing zone. We're a subaru board, but yet were able to help figure out a saturn problem. WOW. I love this place, I wish I never had to leave... Twitch
96 Legacy worth $1300?
SOLD!!!! I would snap that up in an instant!!! Around here (PNW) those don't go any cheaper than $2k and that's the fixer uppers. I say buy it now, change the gear oil, look for glitter, and do a thorough scrubdown on that engine to see where the oil is coming from. Twitch
Slammed hatch
But not quite as nice as some big, soft long travel springs and some aired down 33"s!!! Just like cruisin' in a caddy... Twitch PS: ThirdEyeHatch, I dig it if it works in your neck of the woods. It wouldn't work around here, too much snow and too many bumps, but hey, it looks reeeeeally cool!
Why must my cars be so... aggravating
Well at least you're able to keep the things on the road (and only one has tried to kill you so far ) One thing I would recommend on that BRAT is to check out the fuel pump connection. It seemed somewhat corroded when I installed the pump. So maybe if you clean up that connection your idling/accelerating off of idle problem may be fixed. Also, I would check your fuel filer again. That tank sat for a few years, never know what made its way into that thing. Twitch
LMAO!!!!! Sorry, but I'm glad I let you play with that thing instead of me! Just as a warning, all of my cars seem to operate best at WOT. Not to mention they all have balls Gutless to the end, but if you gotta go, they will get you there. Enjoy! Twitch PS: I don't think it hates you, its just testing you to see if you're worthy of driving it. Nobody ever "owns" a BRAT.
New Project...
So how's that 4Runner treatin' ya? Hope you didn't DISOWN shelby for it... Twitch PS:JK dude, hope its ready to go soon
Worthless Piece Of %@%#$%@!!!
Well I'll be calling you if I need'em! Thanks for the offer I need a total of 8, 4 front, 4 rear. Twitch
Round two with the night wagon. I changed all my wheels and tires over to my new/used tires on chromies, and on the test drive my left front left. Quite literally. And this is after checking and seating all lugnuts and double torqueing with the lug wrench. All four lugs worked themselves off in the distance of 3/4 of a mile. I got the wheel back on, I had my lo pro floor jack with me this time, using lugnuts from other wheels I limped it home. Thankfully legos and EA82's have the same threading as first gen legos, I was able to steal some lugnuts off of my parts lego. So, after all that the nightwagon has a tweaked fender, a chewed up stud, and a slightly scarred rotor. Yeah, this car wants to kill me. Oh, does anybody know if studs from a 94 lego will fit in an EA82 hub? Twitch
Subaru Has best June ever!!
I think I know why the Outback is decreasing in sales. The Forester is the better value, it has more space, a higher ride height and starts out about a $1000 less. I wonder how the 2010 model will affect it? Twitch
Yes, I went to the light side...
TWITTER!!!! I'll be twittering on occasion so feel free to follow me, and I invite you to join the light side and start twittering! http://twitter.com/TwitchdelaBrat Twitch
Thanks, but I have a decent set of tires on chrome rims, I forget what they're called, but they are riveted with round holes. Twitch
Ok. The air compressor that I could access was 500ft as the crow flies, but if I followed the roads, it streched out to 1500 feet. And the people who designed the parking lot made the parking lot edge taller than the street, so it goes up about a foot, then drops steeply onto the street side. Then I have to go onto the main road through town for 700 feet then pull into a parking lot that has two speed bumps before i get to the Air. Meanwhile the irritable cops are roving the streets. Any other questions? Oh, and a roofing nail was the culprit that killed my tire. Twitch
The Nightwagon decided to strand me at work tonight. I've been limping along on a slow leak in the front left, ya know air it up for the day and keep on truckin'. Well, it's not that tire that decided to die. On my last pizza delivery the right rear decided to let go and I could hear an audible hiss as I walked into the store. It's late (obviously moron) and so I finished cleaning, closed up and had to call my parents cuz this idiot forgot to put his jack and spare in his new car. And I'm only 500 or so feet from air, but I'm sitting on chrome Jackmans so I don't wat to thrash my wheels. Oh, and that 500 feet turns into 1500 and a nasty hump, two speed bumps, and some extreeeemely picky and irritable RatDrum cops. Sigh... Twitch
2010 Legacy Test Drive
Twitch de la Brat replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do like the fact that they pretty much kept the front end the same. But it looks like a Buick in almost every other way :-\ It's too luxury car, but I guess that's what the Legacy has become. I just wish they would make a new platform to base the Outback on, because I see the cushiness making its way into the outback, but I guess that's what the Tribeca is for Twitch
