6
Everything posted by Twitch de la Brat
Looks like a Californidahoan's truck. Good looking work though. After the BRAT is done you might be getting a call. Twitch
I have considered cutting my Parts lego off at the firewall and making it into a bean style trailer with 4 doors and hatch. But Idk if it'd be worth it. Twitch
We got a Jeff Gordon Fan!!!! :banana: ANd I like your setup. My shop is currently my Parts lego :-\ Twitch
Ultimate Subernoobie
Twitch de la Brat replied to Amokster's topic in Meet n' Greet. Your USMB Welcome Center
That sucks, but at least you still have options. And 12-14k is the average price for an 03 baja around here Keep your eyes out for one, but be wary as people seem to be putting the baja into the same category as the BRAT. Expect the price to be miserable. Twitch -
Sorry nip. Its a 90 body, 91 engine, and a 94 tranny. Lets just say this thing has a Carfax rap sheet that'll make a convict look away with shame. I installed the spec clutch for a 90-94 lego, after I verified parts #'s, checking to make sure they didn't change anything on me in those years. I had the flywheel resurfaced the day I put the car back together, ummm Any more details wanted? Twitch
Problem is, this car was originally an auto... So anything that crops up now may be severe, or nothing and something I just have to get used to. Like that %#@$*&^!@% squealing pilot bearing. But I did have to make a new spring clip, as I either lost one, or it never came with the donor car. It was made out of spring metal that had about the same properties as the clip. But, the shuddering is happening when starting as well, so could that be motor mounts? Tranny mounts? Twitch
You might ask TomsSVX, he put an EG33 into a 99 SUS. He runs an SVX repair shop, I believe, and my have some good pointers for you. Or he may even have a whole diagram on how to do it, Idk, just ask him. Twich
Many of here in the states would almost kill for one. Me included. If I had an EJ d/r with diff lock, my car would be UNSTOPPABLE!!! Twitch
Soak that entire area for AT LEAST 24 hours before attempting anything. Believe me, it will make your life A LOT easier. I just pulled apart (and put back together) my 90 lego rear suspension, and I procrastinated doing it, just spraying it with PB Blaster like 3 or 4 days in a row before breaking bolts loose. Even then I had to use a 3ft breaker bar with a 5ft cheater pipe attached to break loose that giant bolt, as mentioned by grossgary. So use as much liquid wrench, Kroil, PB Blaster, or even just brake cleaner as you want. Twitch
New symptom! It shakes and there is an audible rattle or repetitive thudding when I start it. Just like when I'm starting off. And since the clutch has been used a bit more the shuddering has been reduced so I'm guessing it was just because it was a new clutch, but this new symptom is making me think I need to replace my engine mounts. But when I had it apart they seemed just fine.... Any other suggestions? Twitch PS: I did a search and came up with nothing.
Lowering a 1st gen Brat
Twitch de la Brat replied to ninefourteener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would say ask Bill (TheBeastIDrive) but he may only tell you to lift it :-p Ummm, just try to move the suspension components up and reduce the height of the rear struts. No real ideas here, but if I figure anything out I'll let you know. You might try suberdave or Numchux. Twitch -
How to: Incressing Boxer rumble? (EA82)
Twitch de la Brat replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll jump in before GD on this one, IIRC, it increases scavenging and allows for proper back pressure so you don't burn valves and have decent low end grunt. Twitch -
Poll: Favorite Old Gen Model
Twitch de la Brat replied to Twitch de la Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry, but I had a maximum number of selections I could put in, and that is the number of models I put down. Had I been able to separate every model into their own category, I would have. I apologize, but it seemed that the wagon and the sedan were the most similar component and body wise. Twitch -
Holy crap that is Green... Thank you!!! Twitch
I just replaced the clutch, transmission and lower ball joints in my 90/91/94 Legacy, and it shudders and shakes when I release the clutch, but only sometimes. If I burn the clutch, it doesn't shake and accelerates smoothly, but if I release the clutch normally, the whole drivetrain moves a significant distance as it shakes, and the car's motion is jerky. I have double, even triple checked my bolts, and they all are tight and everything is attached properly. Grrrr, is this normal or what? Twitch PS: Is it normal for the shifter to be able to touch the driveline when shifting?
