fajr22
Everything posted by fajr22
  1. thanx guys for the Help cage is ready and I will start other assembly this week!! fajr22@yahoo.com
  2. Thanks for great info, i have been gone a while and when i came on earlier this week it said the board had been hacked.. So anyway, the 1.8 runs and drives it was parked because clutch was smoked, i have 2 of them and the turbo motor.. i am open to reasonable offers on all.. Lastly does the 2.2 turbo have better injectors?? thanx fajr22@yahoo.com
  3. Let me know what you guys need from my parts collection I would be more then willing to sell some stuff to fund the car.. FRED ASHMORE
  4. I have a set of older heads from the 2.2s.. Do the turbo heads flow better?? Where do I get the commetic gaskets for the swap, and the place I thought I was ordering the cams from can't get them, is there a link to a vendor or a recommended vendor to buy these from... Also which injectors are best, I have a slew of parts laid out and want to get it put together soon if at all poossible,,, THanx fajr22@yahoo.com
  5. Your are correct, I was asked to leave the track and not bring my mustang back... I raced there for 10 years, and wehn the tech guy changed so did the rules... The problem was he could not disqualify me from the race, he just didn't like me, and knew i was doing something but did not know what.. I figure if i build a Subaru there is nothing to compare it to... The only reason I would not run an old subaru is i live in the rustbelt, and they are gone.. no parts to choose from.. i did know the 2.5 was not available in my car, but in short... i have already taken car of that issue.. the Sohc block has mor mains then the dohc, is that correct?? I am piping now and will post pics soon.. keep the info coming , I am currently ordering cams fajr22@yahoo.com
  6. By eliminating certain cars it limits what you have to tech... Can you imagine the number of cars you would have to be familiar with to tech all 4 cylinder cars?? Most classes have two or 3 makes to tech, when you get in the ministock class of 4 bangers, there are literally a hundred options.. That in a nutshell explains it.. This is also why I have gone away from the Mustang is because its over teched.. fajr22@yahoo.com
  7. thank you very much i plan on spending a lot of time here and appreciate your honest effort.. fajr22@yahoo.com
  8. i know this is my first post, but I was taught when i was young, if you don't know ask, it can save you a lot of money down the road... So here it goes.. I am building a race car, a ministock. The rules say i can use any car after 70, it must be 4cyl 2.5 liters or less 2wd, meaning fwd or rwd, but not rwd IRS.. The car must be less then 102 inch wheelbase, and cannot be labeled as a sports car.. Due to past rules written against me they no longer allow turbo chargers.. The car has to weigh a minimum of 2300lbs. The car must appear stock and use stock efi or carb components for year make and model.. This being said, and after a trip to the track to watch a honda prelude (190hp stock) clean house, I have chosen a 96 Impreza 2 dr, 2wd.. The car has been converted to fwd only, and I have removed the 1.8. What I have so far is a 2.5 sohc shortblock, a 90's 2.2 legacy turbo drop out and a non turbo 2.2 drop out and 2 1.8 dropouts.. I have a fidenza 2.5 flywheel along with a race clutch, CAI and a chip.. I do not mind spending money , but I only want to spend it once.. What is the easiest power out of this setup.. Ie; What cams? What heads on which block?? What throttle plate?? What trans will hold up to the power?? what injectors?? what exhaust?? What type of power can i expect from it?? The track is a 1/3 mile asphault oval, and I held the track record in a full race Mustang @ 17.89 on Radials.. The reason I am going away from mustangs is most track rules are written around them and I want to race something that is different and has an abundance of aftermarket parts.. I believe with the research i have done the Subaru is the right candidate, I just need the right recipe.. Any help would be greatly appreciated.. I will update with pics as i progress on the car... Any parts you have to sell and links would be great as well thanx fajr22@yahoo.com
