Everything posted by crash321
I have a 98 outback 5 speed 2.5 litre, 155,000 miles. I was on my way to work, 5 hour commute, when after 2 hours into my drive my right turn signal came on steady but not blinking and did not go away. I came on by itself and not from me using it. The left blinker works fine. I can get the right blinker to get a little bit brighter if i turn on the blinker with the stalk but it will just do it one time. and go back to being just "on". I tried disconnecting the blinker relay under the dash on driver side above the kick panel, but the lights (front and rear turn signals, and dash indicator) did not go off. I then tried disconnecting the hazard switch but to no avail. I even removed the bulbs and and the indicator is still illuminated on the dash. Then after 4 hours into my commute, my cruise kicked off and the speedometer fluctuated back and forth and then quit working altogether, then triggered a CEL. After I got to work the engine stalled but started right up again. I had to disconnect the battery so that I can at least start it when I get back to the car. Any ideas will be great. I am not at the car as I am over the road right now but will return to the car to go home on tueday evening. Thanks so much sorry for the length but wanted to be thourgh.
a sad day 01/03/09....
crash321 replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I will pray for him and his family. -
Lights on stock bumper?
crash321 replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is the ultimate stone guard!!!! -
Even if the "big wigs" wanted a thinner oil for EPA ratings, Engineers can engineer the car to those thinner oil specs. That is why they call them engineers. Take the Ford Escape with the V-6. That vehicle requires 5w-20 motor oil because of the tolerances. People who think that is too thin were putting 5w or 10w-30 in thinking that it would be "better". What started happening is that those engines started siezing up due to oil starvation. Ford investigated why that was happening and found the oil viscousity was to thick. So because you think that it is ok to put thicker oil in than required because you think the "bigwig" is putting the screws to you, then you should not be surprised if one day you buy a newer vehicle and do not get the long life that it was designed to get by using the thinner oil.:-\
thanks nipper and gbhrps. It does sound like the motor. Once I remove the motor and drill out the rivets, what kind of grease should I use? I have regular wheel bearing grease. Also the shaft for the arm needs some grease also? I thank you guys for your expertise. Also nipper, I drive from saginaw mi to chicago, so When it snows or rains, the build up of snow and water is constant so I will have it on for two to three hours at times.
how many scooby guys from michigan are there!??
crash321 replied to codytotheh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought marlette had that distriction. Sorry to dose your caro thunder HEHEHEHEHE -
So insurance wants to give me...
crash321 replied to Yo'J's topic in Old Gen.: 80's GL/DL/XT/Loyales...
First off, why would you turn in $130 in damages to your car. That is something you should take of yourself. Turning in a claim is only going to jack your rates, even if it wasn't your fault. I say (at the risk of pi$$ing you off) suck it up and absorp the cost and get it fixed:-\ -
I have a 98 outback wagon with a noisy rear wiper and need some ideas what might be the cause. The symtoms are that it screaches rythomically(butchered) as it goes back and forth when it is cold outside.:-\ When it is warm, the noise is not there. Also after it has been on for awhile, 1 hour maybe, it is quiet. also is it suppose to operate constantly or is it suppose to operate like a delay wiper, mine operates constantly. Thanks so much for your input.
I am a firm believer in using what the manufacturer recommends. They engineered the car to use certain lubes so that the car will live a long happy life. They are not trying to get people to use a cartain weight so that the car breaks early and often, that would cause people to run like he:: from that brand and never go back. My 98 calls for 5w-30, so that is what I will use. Engineers are not stupid people, they recommend things for a reason.
I think nippers point is that the tolerances on these heads are so tight that they should be professionally checked with the proper tools and equipment that any yahoo will not have in his/her garage. If the pro shop with the proper tools finds that everything is in spec, then they are not going to machine the heads. Like he said, why do the job twice.:-\
Regarding the crumbling, I see you reside in N.E. Cali. If you are around the mountains, do you know if the road crews put out that liquid deicer before a snow or ice storm. If they do, that could be that cause of the crumbling problem. I'll explain, I am in the trucking industry, since juristictions started using this liquid deicer, maintenance faucilities started noticing that brake shoe friction material on the trucks and trailers where delaminating, cracking and crumbling. This is caused by a layer of rust that builds up between the friction material and the metal backer. This liquid deicer is much more corrosive than the regular salt used in most areas. More states are starting to go with this method of pre-emptive deicing because they are trying to cut down on expenses and manpower. The only drawback is that it will reak havok on any exposed metal part on a car. This is also the reason my brand new Freightliner started to rust right after the first winter season, And I washed it weekly!
Is it a metalic knocking noise or could it be spark knock? Being that it only shows up under load going up hill makes me think spark knock
:lol::lol:I give you the Mr. Obvious Award! That quote just caught me funny!!!:lol::lol:
