Everything posted by crash321
Being that I am home, if I end up out in the garage, I will get a rough measurement for you:)
You must have been tired when you thought of this on at 2 in the morning. You would have lube issues and the chain would break in a "flying plastic bits fit of glory".
Looks like Subaru's evil overlord isnt so evil
crash321 replied to nipper's topic in Non Soob Cars and Bikes Discussion
From the March 2009 Motortrend page 12-13 under title "It's not just Detroit, If Toyota's losing money, what about Mazda, Mitsubishi, Subaru, and Suzuki?" ............. "Subaru having lost its connection with GM, is also "dicey," a source says. The Toyota connection will help keep it viable, which means, potentially, future Subie models powered with something OTHER THAN horizonally opposed engines. The proposed joint venture sport coupe (with Toyota) is on hold however."............... There would be alot of Subie faithfully that would be very P'ed off if they started putting I 4 engines instead of the flat 4.:-\ -
Something like this YESSSSSS:banana:
Is it static that changes frequency with the rpm of the engine, are your grounds good?
Where to get a wrist pin tool?
crash321 replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Like what this guy uses:) -
Hmmmm....milkshake crap on my oil cap....
crash321 replied to mudduck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We have had a colder than usual winter, I vote condensation also. -
I love the witty sarcasm rpiereck:lol:
That sealing stuff sounds like snakeoil. It will probably cause more problems than it is worth, possibly plugging your radiator or heater core. Yes they are know to fail quickly if they are not subaru gaskets and if the torque sequence is not followed precisely. 2.5 motors are just very hard to seal if the proper parts and procedures are not followed. But if everything is done with care (correct subaru parts and procedures) this car will last a very long time:)
Also, no one has mentions the possiblity of a fuel pressure regulator that may be going bad which could be causing these issues, too much fuel can foul an EGR, cause the O2 sensor to fail creating the cat code and cause a misfire on a weak cylinder. Does your exhuast smell rich? Don't just throw parts at it.:-\
Hard Start
crash321 replied to Sundance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Fuel pressure regulator may be going south. -
Although I am not a glass guy, you should be able to drive it home after it set up for about half an hour. Glass guys generally tell you to not shut the door with the window closed for the 1st 24 hours as to not chance a leak. I have had my glass replaced in my cars and have not had any problems.
Yet another Sea Foam thread...
crash321 replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a tick once in a while, but my commute is about 5 hours long, now there is nothing but smooth running goodness every time I run it (98 OBW 157,000 miles)
