14
Everything posted by bratman18
Looks very nice! And it's a 5 spd dual range!! Cool car! This would be awesome to do a EJ swap!! Nice buy!
if you are looking for a direct LSD swap in. You would have to find a VLSD from a 5 spd Legacy turbo 91-94. Other than that you'd have to "build" one from a turbo GL and those are hard to find now as well.
he is on here under scott in bellingham you could possibly ask him some questions.
What are the best front brake discs?
bratman18 replied to jackbombay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The biggest thing is that the drum brakes on trucks are built very big so that they can dissipate heat better and they can take more heat without glazing. They actually work better when they heat up a lot. Obviously any brake will start to fail if they have too much heat built up. But the little drum brakes on cars aren't designed to dissipate as much heat and when you ask a lot of them they are not going to work as well, which is why they are designed to not have a lot of braking power sent to them. Disc brakes are out in the open and have the ability to dissipate heat much quicker. Also brake fluid which is hydraulic fluid starts do break down with heat and in hard braking situations can start to feel spongy, but air doesn't work that way, it can take as much heat as you want to give to it and yes it will expand, but that only increases it's braking power. Yes I did take the class a while back and because a huge part of the test is air brakes, you have to learn all about them and about all types of brakes. I'm not flat out disagreeing with you but there is a lot to look at when talking about the differences between disc and drum brakes. -
I agree about not using drilled and slotted rotors on these old cars. It just doesn't make any since. A decent quality OEM rotor and some good pads will do just fine. And I also agree with replacing your fluid and making sure your calipers are working and sliding properly. It makes a huge difference if everything is properly lubed and free moving! -
Here's mine, I obviously have different headlights now. They aren't great, But they have a cage built around them for protection. I still want to get some more on my Push bar
Bug trucks have drum brakes but they are much bigger(actually overkill) and they also run off air. It's a little different. Take a truck driving class, it's a great way to learn about why they are used on big trucks and why they work better on big trucks and not as well on cars. Heat is the big reason!!! -
Guy has an 85 GL Hatch 4x4 for sale locally
bratman18 replied to ou812's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also look for rust! That.s one of the biggest things! -
E85 Fuel
bratman18 replied to I)arkZrobe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hmmm, that's a good point, I never thought about that. I wonder if it actually works that way. That would be cool. -
The Gen 1 Winch - Best Replacement for Original
bratman18 replied to Crabman's topic in Historic Subaru Forum: 50's thru 70's
If you can, post some pics on here so we can all see the "rare" factory suby winch, Right on the vehicle -
oh okay, well it will sound pretty mean. But that's about it. It doesn't give it anymore power or anything
Yeah they are getting harder and harder to find!! I'm lucky, my Brat came with them! and that's why I noticed a difference, all my others had regular drum brakes!. Even with big tires the Brat stops great! on and off road -
Yes if you could find a set of rear discs, that would make a huge difference! I love mine and saw a huge difference even without adding a proportioning valve! -
Just out of curiosity, why do you want to put this on your car?
All you really need to do is get a complete donor car. Get a 4WD car and take the whole rear crossmember, diff, axles etc and bolt it up into place. You probably need to drill out the holes. But it's the same body as a 4WD car just doesn't have the running gear. You will also need the 4WD gas tank as well. Then after it's all bolted up, hook up the drive shaft/center bearing, and rear struts. It's a fair amount of work but it can and has been done lots of times!
BRAT clutch job with a 4" lift discuss
bratman18 replied to bheinen74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah me too:confused:I'm not disagreeing with you, I just know what I ordered and also know that it works. But I do have a 5 spd dual range out of an EA82, The flywheel is machined so that it works great! And like I said when I ordered it, I cross referenced them part numbers and they were the same. -
Looks like you had fun! So you're liking your new lift. Yeah that thing would go even better with a little bigger and more aggressive tire. Not too big though, you want to have enough power to turn them well. I wish there was someplace around here like that to go and have fun!
Check out his site sjrlift.com or ask him
I actually just joined this forum. Looks like getting some wheels shouldn't be too hard. Put up a wanted ad. There have been a few people on there looking for pug wheels for subarus.
I'll see what I can do, I'll let you know in a few days.
What are you willing to pay for a set?? I might be able to come up with some but no guarantees
My ECM is under the dash on the passenger side just like it would be on a factory SPFI car
