bratman18
    14
Everything posted by bratman18
  1. Hmmm, if the starter is on top, I dunno. There should be a stamp on the enigine on the front towards the pass. side. It would either say EA81 or EA71. Check around for that stamp. Pics would be best
  2. replace with struts and springs from same style car that doesn't have air suspension! They will bolt right up.
  3. I had a friend that had a 2WD EA81 that blew a connecting rod out through the case. It kept running! Finally after several minutes the rod finally caught under the outside of the case and stopped the motor solid. Pretty cool!! I would love to see some pictures once you get that EA71 taken apart!
  4. Yeah that's my fear. I mean the actual surface will be rock solid but how well did it bond to the sheet metal? That's the question
  5. The Legacy crossmember adapter/lift is something that someone should start making! Like maybe SJR. It would be an awesome mod and make fitting a lot of the newer stuff a lot easier! I would imagine that there would be some demand for it as well.
  6. Yeah I understand what you're saying. I suppose it will probably last a long time. Just make sure the fiberglass seals down good! But I'm sure it will be fine. Keep us updated with pictures etc.
  7. I dunno I have heard of quite a few builds where an STI is putting out insane amounts of power. As long as it's done right it will last. But you can't just throw a bunch of bolt ons and computer programs at it and expect it to last. But it is getting cheaper all the time to build these things into monsters! I'm not saying its really cheap, I'm just saying it's getting cheaper.
  8. Just again make sure you don't just cover up the rust, remove it first! If you don't it will continue to eat away at the sheet metal! Good luck with it!
  9. Yeah and that's where I work on my car as well, but, I live in a place where I'm not allowed to tear your car apart or I could get kicked out! So that prevents me! I have spent countless hours in the mud, rain, snow etc. working on my car and it sucks but I gotta do it, but I just can't now, so I have to wait for someone to have space available for me to work on my car at there place
  10. yeah I know these are possibilities but there are always options! He could go all out and if he had to he could swap motors. But I'm also pretty sure he said he had an EA81, that's why I said this
  11. yes! But if you could find a dual range tranny, it would swap in fairly easy!!
  12. I might take you up on that! We'll see once it gets closer, thanks for offering that up! I'm looking forward to it. There is still the slight chance that my wife and daughter are coming and if that happens we might just stay at a hotel. But I can't wait to meet people and their cars!
  13. bratman18
    how to?
    :lol:of what though? Is it a wagon? or a hatch? Does it have roof racks? If it has roof racks than you could rig something up to bolt onto or clip onto those securely. If not Maybe you could install some roof racks from a donor car and then rig something up. I don't see a way to mount to the roof unless you drill holes, and I dunno if I would do that unless you were mounting some racks.
  14. bratman18
    how to?
    What exactly would they be mounted to?
  15. I agree but it's hard when you have no where to work on your vehicle. It seems like whenever I have to work on my car, there's 2 feet of snow on the ground or its raining etc. If I had a place I could take my car apart I would. But where I live I can only do oil changes or small projects. I don't like to use it but I have used it quite a few times and never had a problem and its made it so I could put off working on my car until I had a place and time to do it.
  16. Yeah I wish! I'm 6'4"! But it would just be the easiest. And I don't have a tent anymore! I might just sleep on the ground or something. I guess we'll see!
  17. The door locks are fairly easy to replace.
  18. If you haven't already, try rotating your tires from front to back. It could be tires or maybe even a bent wheel.
  19. It holds 4.3 quarts I think. I usually put in four. Start it, then add the rest until it shows full on the dip stick. I would use 10w40. Thats what I use
  20. Awesome! That bumper ought to take a beating!:grin:So you must be about ready for the harness now! I bet you can't wait to hear it run!
  21. Just make sure you take care of the rust as well. Any rust that is left on there will continue to work on that sheet metal even though it's covered! Glad you were able to get to it! Good luck on it! Lets see some pictures!
  22. If you end up needing another caliper I'm sure someone could hook you up with a decent used one. They are pretty common. I used to have several!
  23. Make sure you wash it a lot too! At least after every storm dries up. And again oil the hell out of it! also when you sanded etc. did you get every little last spec of surface rust off of it before you spread bondo over it? If not, "rust never sleeps!" It will just keep eating away in there, even though you can't see it!!:-\ Good luck! I know how it is!
