14
Everything posted by bratman18
So, I guess I'm building a Rallycross car! 1995 LX coupe...
bratman18 replied to obk25xt's topic in Members Rides
I have a friend that did a similar turbo swap on the same engine. He used a td04, and 06 WRX intercooler as well. but it's mostly bolt on stuff, and a few hoses etc. Looks good! -
Is this trans what the seller says?
bratman18 replied to Zebbadiesel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA transmissions never cam in 4.44. The EJ auto transmission in Forester and Outbacks as well as 5spd turbo Foresters, came in 4.44. Unless someone did a swap already, if it's attached to a 4spd, its either a 2wd 5spd trans, or a 4wd 4spd. -
We're getting the same crap here right now
- 261 replies
- 1
- Restoration
- Coupe
- (and 4 more)
EA81 and EA82 front spring differences
bratman18 replied to iluvdrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did the same as Jono, many years ago when I had my Brat. Great results. I just drilled new holes for the 3 bolt strut top so the entire assembly could bolt in. -
I reported this hours ago to give an idea of how active the mods are on here lol
The arms are the same. It's the Trailing arm brackets that are different.
Damn rust
- 261 replies
- Restoration
- Coupe
- (and 4 more)
Remove the rear seat and open the access panel and you'll see the torsion bar adjuster right op top.
I've always removed the rear, but the front should hook back up, once it's on the ground again.
EA81's take a shock in the rear, not a coilover strut, The torsion bar is the spring.
The Unofficial "How to Lift your Impreza" Thread
bratman18 replied to Kostamojen's topic in Off Road
Rear trailing arm bracket isn't even absolutely necessary on 02-07 Imprezas.But yes, 98-08 Forester struts are a direct bolt in for 02-07 Imprezas. -
A friend of mine recent;y did a similar swap on a 97 Impreza. Used 22t heads, td04, 06 wrx intercooler, and other various wrx stuff. Works great, and runs well!
I'd like to try to make a side by side buggy.
bratman18 replied to utcoyotehunter's topic in Off Road
Load them to photobucket or a similar image hosting sight, and then post the image link here. -
97 Outback Impreza Sport Suspension Lift
bratman18 replied to Glover45's topic in Subaru Retrofitting
They swap right in. The only thing you need to do is swap your rear top hats, onto the Forester or Outback struts. 98-08 Forester struts, or 96-99 Outback struts will fit. And with your body style, it's also best to use the Outback trailing arm brackets to re center the rear wheel. Or they can be blocked down. -
If you use your springs on forester struts, or visa versa, the struts will wear out prematurely. You really need to match the springs with the struts they came on. And yes you'll need the forester sway bar brackets to retain the sway bar. -
Chris, there's a full subaru wheel cover that sets into ppace, then you rotate it, to lock it into place. There are actually little plastic locks that are attached to the wheels, and the wheel covers twist into them. Not for sure that's what he's talking about. It wasn't the best design though, and it's common for them to not stay on.
Wanting to swap my 4-speed for a 5-speed
bratman18 replied to BRATwurst's topic in Subaru Retrofitting
It's not necessary to have a custom driveshaft made. You just use the driveshaft from the 5spd car. You have to install a center bearing mount, but that's not expensive or difficult. -
Get in touch with Anderson Design and Fabrication. Andersondesign-fab.com He builds Subaru lifts, and has done more of the newer than pretty much anyone. He's on here as well.
- 3 replies
- off road
- adventure road trip
(and 1 more)
Tagged with:
