14
Everything posted by bratman18
That grille will fit between the headlights just fine, but will NOT fit with that bumper. The Outback and GT style grilles need their own style bumper as the grille itself is taller, and needs the cut out in the bumper for it. So if you changed to an Outback or GT style front bumper, the grille would slip right on.
A lot of the newer ATV tires are rated for a lot of weight, easily enough for an older Subaru. They have many in 14" rim size too.
I had that size on my BRAT, but it had a 3" lift, and still rubbed in the front a little when turning tight. They will not fit a stock BRAT, unless there is A LOT of trimming and bashing done, 2" will probably work, but still may need some extra room
Clunking sound on acceleration. 86 brat.
bratman18 replied to fattie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I checked them. The rubber is quite flexible, but they aren't broken. And it's a little more involved on this to change the tranny mounts as it is a custom mount for the 5 spd dual range swap. -
I consider them fine, because it does not feel like the axle. I drove it last night. I have had more bad axles than I could even count, and this does not feel like a bad axle, or sound like one. Like I said, it's hard to explain the symptom. -
Bearings and axles are fine. Definitely not either of those. It's hard to explain. Seems like something is loose, like a lift block, or a mount or something, but there is nothing loose -
I didn't do the work on that other car. There was a guy here in Maine that did. I have built rocker guards before though. I used to 1" pieces of tubing side by side welded together to span the length of the rocker panel, and then two pieces of C channel attached to them on each end going inwards, then those get welded to a long piece of C channel that gets bolted through the floor with BIG washers. They work great!!!!, very strong, protects the rockers, and looks pretty cool on a Suby. They kind of need to be built on the car to get them to fit how you want them.
Which seats will fit my brat ?
bratman18 replied to subie94's topic in Old Gen.: 80's GL/DL/XT/Loyales...
XT6 seats work great, need slight modification, but bolt in for the most part. And they are much more comfortable, and have height adjust! -
Bought Bratman18's Brat.
bratman18 replied to fattie's topic in Meet n' Greet. Your USMB Welcome Center
Welcome:grin: -
185 70's or even 185 80's would work. I used to run 185 80's on mine before the lift.
There are 2 versions of it. The EA81 version, and the EA82 version. The levers go in opposite directions to go in and out of 4WD
Haha, the switch on top of the steering column? Congrats on getting it fired up!
Was the virgin switch on?
So GD, do you have any knowledge if the SVX axles would click into the SS rear diff? Sounds like they have the same VLSD inside of them. Seems like the SS came with stubs to accommodate the "different" insides it has, and the SVX used male ended axles that were shaped a little different to accommodate this. So do you think if you popped the stubs out, that the SVX axles would slide in, and function/seal?
Yeah I have this stuff all installed in my Forester XT actually. I am having serious issues with the axles. It seems like they are trying to pop out of their cups on the outer joints. It cause insane noise and vibration. I should add that they are just about completely horizontal with little or know angle because the Forester is lowered. I figured they would be better this way, but they are not. I wanted to upgrade to the newer style axles, but I guess I can't.
