floortom
Everything posted by floortom
Qman - thanks for quick response - Ken is sleeping so I'm monitoring this - EA81 - so no timing belt - he did check all the fuses - or at least he said so. I will have him check coil and also check to see if distributor is moving. Thanks! Lynn
I CHECKED ALL FUSES AND LINKS UNER HOOD, TRYED TO HOTWIRE TO COIL NADA.... ENGINE MANAGE BOX BLINKING,6 SLOW THEN SOME RAPID HELP THANKS. KEN IN VANCOUVER
need licened dealer for estimate...crashed car
floortom replied to floortom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can anyone in Portland area help me out - probably just need a phone call. Thanks! -
HI floortom here, I need a person with a dealers lic. in the portland metro area to give a estimate of what my wagon was worth. was crashed and going thru trial soon. Most likely just a phone call. was a gl 4wd 1983 in great shape, have pics from wcss. no rust or dents. please call ken in beaverton area @ 971.295.8583 thanks in advance.
Hi floortom here, does anyone in the portland area have a working carter weber carb to part with? My buddy needs one for a 83 non turbo. he will pay cash for a weber conversion or old carter /weber.... richie rich said the carter is a failure. Oh well, thanks in advance, call ken in north portland @503.735.1583
Bolt on 90 amp alternator
floortom replied to Splinter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am...floortom here, I just bought a maxia alt for the swap, I havent put it in yet due to changing the pulley and spacer. I live next to wrecking yard row, so parts are plentyful. What model, year ect. are you using? great pics. thanks in advance, floortom -
My hatch had same prob, 2 different things were going on, first the cable was stretched. 2nd, the hole for the cable pin on the ped, was elongated, from exessive pressure, a bad cable that was freyed. ken.
Very cool design....looks great. Sleeping bags ect.
Hey floortom here... i lost a head gasket and replaced it. after starting...got this huge plume of smoke. checked plugs, ect, started to dougt my work... tourque wrench...ect then i took off the y pipe to see which side was smokin...after start.. no smoke from motor...reconnect the pipe and it was like a tire fire. ran it in 3rd for 10. mi. @30 mph.down a rual road and it cleared out.. any imput?
When going to the wcss-11, i lost a heater line and dumped all the coolant, its never been the same. Ive replaced both head gaskets, thermostat,{ which was not present before} and put a newer macs radiator out of my gals hatch, which never gets above a 1/4 on a hot day. put rad. in today, thinking it was old and clogged. still just as bad , if not worse. i looked the heads over well and did not find any cracks. maybe warped? need a ea81 in portland. pay cash, ken @503.735.1583 thanks in advance
the ring with timing marks fell off!!!!!
oh yea...90' legacy mpfi 2.2 thanks -
can i convert ea82 gear in a hatch?
the legacy will be aaa'd home soon, i can't wait! very excited. it wouldnt start after the crash..about 2 wks. ago...pushed the first front 6" to the right. seems the rad is still intact. not that bad mech., but body is unrepairable. $50 seemed reasonable. thanks, ken...i love this site. -
cool...thats good news! my father owned a tv repair shop in the 70's and i dabble with audio/vidio pc boards, but ecu stuff is so sensitive im spooked. ill need a lot of help after the shoe horning is done.also... is there a man. 5spd....like the dual range in my hatch for this unit? any thoughts? ken -
at a quick glance i seen mpfi 2.2 full time awd, all ajustments are computer controled. i worked at six states drine train in the driveline dept., so spliceing slip/spline/yoke issues i think i can get i grip on. as for matching two cv joints...mabey. the nuts and bolts of motor mounts and cross members would be a great help from anyone that has done this with sucsess. all advice is welcome......thanks, ken -
<P>can i put a legacy running gear in a older gen car?</P>
hatch clutch size and other dissmal failures help!
I 'm screwed...girl frd unit is pissed. so am i ... .cant find the kit, wrong parts evry time...why is the hatch so hard to buy for? Differnt stuff, brakes i can understand ...spline size? -
Hi Ken from Portland here. I'm having problems locating a clutch for an 86 Subie Hatch. I've been sold the wrong one twice due to differences. Clutch disk is 8 7/8" Small spline Old sytle throwout bearing The first one they sold me was the right size clutch disk but I could tell the throwout bearing was for a different model and the spline size was too big. It measured 1". The second one they sold me the clutch disk was an 1" too small and it had the replaceable throwout bearing but it was too small. I called the Napa warehouse and other various places in Portland and the closest one I could find was 5 days away in New Mexico. I rented a trannty jack this weekend, and it sits there mocking me... Can somebody like Ritchie Rich or someone like him in the Portland area locate one for me - they have to be here. Failure 2 Pilot bearing is stuck. I bought a $44 remover but the jaws were just a shade too large so I filed it down so it would fit in the hole. Yet it didn't have enough to pull the bearing - it pops out. Tried the grease trick with no success. Is there a better puller or method I don't know about? Failure 3 Exhaust studs for the catalytic converter - one on each side broke off. After much babying and preperation they still broke off. What is the best method to remove them? Still about 3/4" of an inch stick out from the head. Thanks for any help in advance! Ken from Portland
looking for the master kit, pistons, cam, valves, bearings, gaskets and ect. floortom in portland or.
extra super goovy cool in portland or.
thanks,all still good.
