About BobBrumby
- Birthday 09/08/1986
Contact Methods
Website URL
http://
Location
Brisbane, Australia
Ezboard Name
Test
BobBrumby's Achievements
Subaru Nut (7/11)
13
Can anyone tell me if the awd rear strut tops are different to fwd? I have recently converted my legacy wagon to awd but needed to use my original rear 95 gen2 fwd strut tops on the 93 gen1 rs rear struts and springs I used for the conversion. I had to do this as the gen1 rs strut tops has the studs in a slightly smaller circle where the strut top bolts to the body. I am aware that awd and fwd struts run at slightly different agnles because of the difference to where they bolt to the different hubs. So should the fwd rears stay or go for some awd spec? Cheers
I have had my 160,000km 95 liberty ej22 for 2500km now with just the one problem. I think one of the injectors is leaking because it takes 3-4 cranks to start if you have not driven it in a while. When you start the engine just after turning it off it starts on the first crank. This happens exactly the same no matter hot or cold, this is why I think it may be a leaky inkector. Should the fuel pump presurise when you key on or when the altinator starts turning like the ea's? Is it just the two o rings per injector?
Found A broken vacuum hose on gen2 liberty's ej22 it runs to the fuel pressure regulator so I reconnect it. Now when you first start the car the idle osilates between 250rmp and 1000rpm till it petters out after going up and down up to 2 or 3 times. I thought my car would run better with a functioning fuel pressure regulation system? Could this be the ecu relearning?
