About 952.2LX
- Birthday 01/01/1970
Gender
Male
Location
Springfield, MO
Occupation
Industrial Packaging Designer
Vehicles
1995 2.2 LX Impreza sedan
952.2LX's Achievements
USMB is life! (4/11)
10
Update. We finally got to it again. My buddy pulled the pan to have a look and he said a bunch of little bolts fell out and wires were all loose. He matched all the runs and wire and little bolts to the old tranny for a diagram. And it seems to be shifting fine now.... Thanks for the help everyone. Moral of the story... go ahead and pull the pan when your tranny is actin up...you never know what you'll find.
No we did not jack it up by the oil pan. and no dents. The P code was P0720 and it did not come back on after cleared. No flashing AT light at start up. another symptom ... when in drive and at say 3500 rpm in D.... and let off the gas.. the engine drops to idle. but in 3rd it does pull the motor down. We are gonna try reading the codes. and will reply later.
Ok, here is the run down. 1995 impreza 350,000 miles. Salvage yard tranny replacement. When we were replacing the tranny the idiots at the yard had cut the rear speed sensor....which is not necessary. So, we spliced it and installed the tranny. Upon test run it wont shift to 4th and when I let of the gas the rpm drops to idle. Also there is a bit of shuddering around 40mph up to 50 then "seems" to go away. We put a reader on it and it threw code for "clutch selonoid open"...which from what i understand its supposed to be open? What is wrong? What do I need to do? (besides get a new car...which is what everyone is saying....why are you doing this to this car....I say...well cuz i can. :) ) Any and all help would be most appreciated.
LOL.....funny posts. I had the same problem with my car in my shop a few years ago. First time i found where the mouse mommy and babies where......... when i turned the heat/ ac fan motor on high....... hmmmm whats that buzzing/grinding sound. After awhile it went away. A few days later my car smelt of death.... had to find it..... suspected fan motor area. Removed fan and blade and whammyO! A headless mouse stuck in the fins ! ! With little dead babies also.... FUN ! ! ! Some time later i was working on the top end of the motor and couldnt' see down to the top of the block...... some sort of grass is there.....pulled on the grass.....and more and more came out with leaves and clothes and it was a full mouse nest in under the intake and crossover pipe... ! AWESOME SAUCE!! Moral of the story...... check everywhere for mice ...cuz they will get in there.
