Olnick
10
Everything posted by Olnick
fuel pump?
Olnick replied to ashleem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Being a '95 it's most likely OBD-2, so you can try the Autozone route--or seee if your mechanic has a code reader. Happe Easter all! -
fuel pump?
Grossgary makes an excellent point--check the basics first before you start throwing big (expensive) parts at it. His list of sensors and connectors is a good starting point. Tell us as much as you can about the car. How many miles on it, did it have starting/running problems when you bought it? Did you do the timing belt, alternator, etc. yourself or did a mechanic work on it? I'm guessing from the price you quoted a mechanic did the work--if so, you might want to ask him for input. And if you need help or specific advice be sure to ask here. Good luck! -
Antenna Mast
Olnick replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Great line, tc! That is truly funny. -
Hello New Gen!
Olnick replied to Sister7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Wow, that is one shweet looking ride Sis. What year is it? Does the engine look as good as the rest of the car? Did you get maintenance records from the previous owner--or do you already know the car's history? -
Im stumped!
Olnick replied to PeterD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Another perplexing problem solved! Way to go, PeterD. Am happy that you found the problem (And solved it too!) -
First of all, what is your year/model/mileage? To answer your questions . . . yes! Extremely sluggish running and undoubtedly miserable gas mileage. A few years ago mine ('95 Legacy L with MT, about 100k miles) stalled in afternoon rush hour at the busiest corner in town and I had to push it across 3 lanes of oncoming traffic into a driveway! Later replaced the ECTS and it's run like a champ ever since. Night-and-day difference. The sensor, IIRC, is at the rear passenger side of the engine, kinda' hidden below the IACV. (Good time to remove the IACV and give it a good cleaning?) Try a search--I know it's been talked about a lot. Sensor cost less than $30 (back then). Go for it! And good luck.
