Olnick
10
Everything posted by Olnick
You're doggone right--any sensor should last longer than 5 months! (If it is, in fact, the TPS that's failed again.) If I were you I'd go back to that dealer and have a nice chat with him. Ask him to explain their failure to solve the problems--then come back here and let us know what he said. Myself, I'd probably start looking for a good independent mechanic. Anyway, good luck and let us know what you find out.
Leinad, sorry, after I posted I noticed the year of your car was in the title line. As to your steering problem, it could be the power steering pump. Mine went out awhile back and it made a terrible racket when turned to the extremes. How many miles on your Outback? The TPS may or may not be the culprit in your rough running. Best way to check is to pull the OBDII codes again (like the POxxx you had earlier--but I can't find a "PO112" in my list!) Not to try to cast doubt, but do you trust whomever did the TPS and belt replacement?
Seafoam......
Olnick replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
1) Use the search function. It's been discussed here many times. 2) Read the directions on the Seafoam can. -
code 0420
Olnick replied to jct61765's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ah, but xoomer--you've already proven your intelligence. Tou drive a Subie and you frequent this board! (And I'm not being flip. I mean that sincerely.) -
First off, don't panic. Subaru fuel gauges are notoriously inaccurate. Best to keep handwritten records. Reset your tripmeter at each fillup and note milage and gallons added--then divide miles by gallons to get your mpg. And, as noted earlier, do this for at least 3 fillups before drawing any conclusions. By the way, your tire guy is sharp. AWD cars should have all 4 tires matching. Let us know how it goes.
Sounds like a classic case of burned/pitted contacts in the starter. They're cheap to purchase and relatively easy to replace, but you do have to remove the starter to get to them. Whatever you do, don't let anyone sell you a new or rebuilt starter yet. Try a search--contact replacement has been discussed quite a bit. Then if you have questions fire away!
