Olnick
10
Everything posted by Olnick
Aw, shucks! My favorite subject and Legacy777 beat me to it! Really, FreeLegacy, you'll be amazed at how easy the starter fix is. Two electrical connections and two bolts--one on top and one below--and the starter lifts right out, from the top no less. Open up the back plate of the solenoid--three screws holding a triangular shaped backing plate IIRC--pull out the solenoid shaft and you'll see the two L-shaped copper contacts that Legacy777 mentioned. They'll probably be pitted and worn. Replace them, put it back together, slap it back in the car and you're ready to go. Good luck to you. Well, sounds like you don't really need luck--you got the car at the right price and you found this board (most helpful people you'll ever meet) so you're well on your way!!! By the way, '95 was a great year for the Legacy!
Betcha' it's nothing more than worn contacts inside the starter. It's a common problem. Just a coupla' bucks to replace--compare that to the cost of a new or rebuilt unit! Not too hard to do either. Search here on the board as lmdew suggests. And by all means do what blackbart says and check/clean all your electrical connections.
Another thought based on KStretch55's approach--with the engine idling, spray "starter fluid" around the vacuum hose connections. Then if there's a leak you should hear a slight revving. Never done it but it sounds like a neat trick! And I tend to agree, the rattling is probably loose heat shield/shrouding--a common problem. Do a search here on the board as it's been discussed recently. Good luck!
JohnnyB--just what bfg9k said. I disassembled the intake ducting, removed the MAF box and sprayed the wires (used brake cleaner, hope that was okay!). I'm just very leery of touching those fine wires with anything, even a Q-tip. bfg9k--I don't recall losing any coolant when I replaced the temperature sensor, but I might have. If you do lose some, use Setright's "front-end-uphill" technique and carefully burp the upper hose as you top up. Brings up a question I've always had--why didn't Subaru provide a bleed valve at the hgih point of the cooling system to allow the release of trapped air? Might have even saved a few head gaskets along the way!
JohnVT--at 124k changing the front O2 sensor is probably a good idea. It's really not that difficult. Again, search here on the board--lots of good info. Check out oxygensensors.com for decent prices, and if you don't mind a bit of splicing/soldering you can buy a universal model and save even more. Go for it. And good luck!
Easy answer. It's the sound of your pistons and small pieces of engine flying by you! Sorry Langdon, couldn't resist that one. Check your rpm numbers--I think you've got one too many zeros in there! Seriously, since the sound happens in such a specific range it could be as simple as some kind of harmonic or resonance causing a heat shield on your exhaust to vibrate. Can you somehow identify the location of the buzz--maybe have someone hold the rpms steady while you listen around the car? If the car seems to run smoothly it's probably not life threatening. Good luck.
I'm no expert but it sounds like a classic case of the oil pump's back plate loosening. Search the board--there's been a fair amount of discussion of this. Whoever did your timing belt last year should have checked the oil pump sealing (new o-ring and "loktiting" the screws) because--guess what--you gotta' remove the timing belt to get to it! Sorry. Good luck.
EJ22T HLA noise
Olnick replied to XSNRG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
BigMattyD: Sweet photo of engine! (Izzat what they look like inside?)
