Olnick
10
Everything posted by Olnick
Can you describe how it "sounds loud?" Clicking/ticking, thumping or banging, roaring? Does it sound like it's "inside the engine" or is it an exhaust sound? Give us as much info as you can--maybe even an audio recording--so we can try to narrow it down.
Intro 912126 Philadelphia
Olnick replied to 912126's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to USMB! Wow--25 years, one owner--that's great! Tell us about your car--mileage--pictures? -
That '96 in Chino looks nice. Just be aware--that was the very first year for the DOHC 2.5 and IIRC it required premium gas.
EJ25 DOHC Engine
Olnick replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
"Since it will be out" . . . Yes! Replace the oil separator plate on the back right (passenger) side of the block. Also remove the diamond shaped access plate on the left side and replace the O-ring inside it. Inspect the rear main seal but don't mess with it unless it's really bad--trying to replace it usually leads to more problems than you started with! Good luck. -
EJ25 DOHC Engine
The '96 2.2 was not interference. That started with the '97 model. -
Welcome to the USMB, Stoltenberg! Good catch on the air hose. That is totally inexcusable if you had the car at a Subaru dealership--they owe you an explanation and probably a fix! I doubt that it broke anything. Hopefully others here will offer help on the misfiring and hard starting. Good luck--and keep us informed with the outcome.
Timing Belt
Olnick replied to DCor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I suggest you use Subaru OEM crank & cam seals and the oil pump O-ring too. Seal the pump to the block with anaerobic sealant or Permatex Ultra-Grey--just make a nice, even bead and don't overdo it. You don't want bits of that RTV breaking off into your oil. The oil pump backing plate does not need any "sealing." You just need to tighten up the screws holding it on--they often tend to back out. Some folks Loctite those screws. Good luck! -
Hello! New to the community and the board!
Olnick replied to cmiertschin's topic in Meet n' Greet. Your USMB Welcome Center
Welcome aboard! Congratulations, that's a good looking ride. -
Wow! What a beauty--great buy. Keep us up on your progress.
