Olnick
10
Everything posted by Olnick
How did you find the torn boot--during inspection or was the axle giving you problems/making noises? Might be worth re-booting your old axle if it's mechanically sound.
- 13 replies
- advice
- maintenance
- (and 4 more)
Welcome aboard, Mark. Your approach is very wise--ask questions and learn. And USMB is a great place to do it--very helpful people here. Just one question: What is FCP?
- 13 replies
- advice
- maintenance
- (and 4 more)
nitroman--not sure what the tech means by "camshaft carrier seals." Do you see oil leaking from the bottom of the timing belt cover? There are camshaft seals that would require opening up the front end as you would to replace the timing belt. Normally that would not require removing the engine. Also there are O-rings (at least there are on the older EJ22!) on the front end of the left (driver's side) head and at the rear of the right (passenger's side) head. To access the left one requires opening up the front end. The right one is a piece of cake--two bolts holding a cap on the backside of the head. If the dealer is willing to change seals under warranty, I'd say go for it! Good luck.
The Mizumo kit you got does not include a tensioner--it has the new roller w/bearing that mounts on the tensioner. The water pump gasket is metal, the equivalent of a Subaru OEM gasket. I think it's best to get the oil pump O-ring from a Subaru dealership--it's only a couple of bucks.
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
Great questions! The 5 seals confused me too, so I called them. Seems they had forgotten to shoot a catalog pic for the EJ22 so they just used the one for the EJ25! They'll send you 2 extra cam seals. The odd size seal is for the crank. Most of us use Permatex "Ultra-Grey" to seal the oil pump. It's acceptable to Subaru, although "Anaerobic" is the preferable one. Do a search here (USMB) or on Google or in a Haynes manual for the sealing pattern. Main thing, don't glob too much on--just a narrow bead along a specific pattern. Yes, your '95 EJ22 is a non-interference engine. There's tons of excellent material here on USMB--try a search. I pulled some stuff for you earlier but couldn't get it to link to a post! Will try again later. And keep asking questions!!!
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
Yeah, you're Subaru enough. Welcome aboard!
New and thrilled to have found USMB!
Olnick replied to Beebs's topic in Meet n' Greet. Your USMB Welcome Center
Great place here, isn't it? Good doing on the fix. And welsome aboard the USMB!- 3 replies
- 1
- Swollen O-Ring
- Broken Fuel Pump Filter Cap
(and 1 more)
Tagged with:
New guy with his first 1981 brat
Olnick replied to KnuckleBeast's topic in Meet n' Greet. Your USMB Welcome Center
Welcome aboard, Dan--Congrats!!! Got any pix? -
Cold engine problem
Olnick replied to paulsickorez's topic in Meet n' Greet. Your USMB Welcome Center
Welcome aboard USMB, Paul. Post your question in the New Gen Forum--better place to get answers there. -
From the middle of one ocean to the middle of another--welcome to the USMB, Hoddi! Tell us about your car. Got any photos?
About the copper contacts: You can get a set of new contacts for $15 or less on-line or at an auto-electric shop. I've never bothered with the ring on the solenoid shaft--just clean up the face with fine wet-and-dry sandpaper. One word of warning--there are numerous shapes and sizes of contacts. It's a good idea to remove yours first so you can make a visual match with new ones.
May I offer my $0.02? Before I'd buy an aftermarket starter (new or "rebuilt") from a parts store, I'd pull the existing starter and take it to an auto-electric shop--get an honest evaluation and an estimate for fixing or replacing. Or--go to a P 'n P and grab a decent looking used starter. At any rate, good luck! (And happy new year!)
need help!
Olnick replied to ilovecake's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's great to hear! -
Way to go, Teach! Proud of you. Stick around--as you well know, the good folks of USMB are eager, willing and happy to help each other! (Kinda' the way life should be!)
