![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Olnick
10
Everything posted by Olnick
Sounds like you got a good deal on your car--congrats! Hope the MMO works for you (it did wonders on my son's high mileage '92 Legacy.) Suggest you do the front-end/timing belt as soon as practical. If the oil pump backing plate is loosening it puts extra pressure on the crank seal--which could explain your front oil leak. If you know which end of a wrench to hold you'll be just fine. Shoot, I'm no great mechanic but I've done three 2.2 timing belts over the past few years! For parts check out Mizumo Auto on E-bay. They have a complete kit--belt, idlers, crank & cam seals, water pump (Aisin) and w/p gasket--for $136 plus shipping ($17 FedEx, I think.) Try a search here on USMB for procedures and helpful hints. I'll try to dig up some info and post links. Ask questions here--and keep us posted on your progress. Good luck!
Does the car leak any oil? Do you have to top it up very often? Is it due for a new timing belt? Two things come to mind: 1) Sometimes a small bit of dirt or gunk will block the small passages in the heads. Try adding a bottle of MMO--Marvel Mystery Oil--to your present oil and drive it for 100 miles or so (just normal driving.) Then change your oil & filter. 2) It's possible your oil pump needs re-sealing. Screws in the pump's backing plate often loosen--they need to be Loctited and tightened. That requires opening up the front end--folks usually combine the job with a timing belt change (along with new idlers, new crank & cam seals, new water pump.) Do all that and you're good for another 100k!
need help!
Olnick replied to ilovecake's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
As I said earlier, I'd be very suspect of cheapie parts store wires--"Omnispark?" Stick with Subaru OEM or NGK, recommended by a number of folks here. How did you hook up your knock sensor after you broke the connector? -
need help!
I'm no expert but I'd check the plug wire connections--are they making good contact? Might even consider new plug wires--make sure you get Subie OEM or NGKs (no parts store cheapie wires!) -
need help!
Yeah, sometimes it's the simplest little things! Good job! -
Welcome Out_Back. This is a great place to call home!
Greetings from North Dakota
Olnick replied to Wolfman01's topic in Meet n' Greet. Your USMB Welcome Center
Welcome aboard, Wolfman--you sound like a true Subaru nut already! Car looks beautiful, and 39.9 . . . Wow! Don't know how much help we can be since most of us are driving 15 to 20 year old Subaus (and love them!) But please do keep us up on what you learn. Enjoy! -
Welcome aboard, John. Post your problem in the New Gen Forum and I'm sure folks will offer help.
New here from the Pacific Northwest
Olnick replied to doogie's topic in Meet n' Greet. Your USMB Welcome Center
Sounds good! At 94k just nicely broken in. Got any pix to show us? (Everyone here likes pix!!!) -
Welcome doogie. What did you buy?
