Olnick
10
Everything posted by Olnick
Welcome aboard, Kenichi. You found a great place here--folks will give all the advice and help you could ask for. Fair warning however--they will demand to see pictures! Hope your daughter's a Sweetie and appreciates what you're doing for her! Good luck and keep us posted on your progress.
Welcome!
Brand New Subaru Owner - '84 GL AWD
Olnick replied to JustGo_GL's topic in Meet n' Greet. Your USMB Welcome Center
Hi Andrew--welcome aboard. Wow, that looks like a new car! Good find. Can't help you with the carb, but if you post questions in the Old Gen forum you'll probably get lots of response. Good luck with your cross-country trip--sounds like fun. -
If the CEL (Check Engine Light) is still on the car's computer must think there's still a problem--maybe something other than the O2 sensor. Did you check for codes again after you installed the new sensor? What brand sensor did you use? How did you connect the wires--solder? Crimp? Some kind of "connector box" provided by the manufacturer? Does the car seem to be running better (or at least okay!) with the new sensor installed?
Nice find--great looking Subie! And welcome to the USMB.
Ah, flingability--a rare and highly desirable quality. Welcome aboard, Peter. You're going to love this place. Best resource a Subaru owner can have!
How's the condition of the car overall? Do you like it? Give serious consideration to replacing the engine with a used EJ22. Buy one for a reasonable price, invest $200 for new timing belt/idlers/water pump & re-seal, slap it in. Would give you another 100k or more of dependable, generally trouble-free driving!
Welcome to the USMB. Sorry to hear about your misfortune--but you'll get good, honest, straightforward advice here. Sounds like classic headgasket failure, very common in the 2.5 liter DOHC engines. I think your seller knew exactly what he was selling! You have two options: 1) Replace the headgasket, which may or may not be a good option depending on the severity of the overheating. Or 2) Replace the entire engine with the "bulletproof" EJ22 from '95 or '96 model--a little less power but super reliable. It's a fairly simple "plug-and-play" swap. Talk to your mechanic about it--and by all means ask any questions you have here on the board. Again--welcome. And good luck.
Hi from Lummi Island, WA
Olnick replied to San Juan Sube's topic in Meet n' Greet. Your USMB Welcome Center
Welcome aboard, San Juan Sube. USMB is the best possible resource you could find for practical Subie knowledge. And congratulations on your car--it looks great. In my mind the perfect vehicle to "learn about cars!" Dang, makes me miss my old DL and GL wagons. Many happy miles to you. -
Hello from Phoenix - Again
Olnick replied to azsubaru's topic in Meet n' Greet. Your USMB Welcome Center
Welcome home, azsubaru! Now let's get going on that Legacy!!! -
You probably know this already--great opportunity to "freshen up" the front end! Make sure you use a Subaru OEM or equivalent water pump gasket (coated metal--not the "paper" kind!) Might consider a new thermostat too--again OEM or equivalent (don't use a parts store cheapie!) Replace all idlers and make sure the tensioner is in good condition. Replace o-rings in the cam caps (left front and right rear.) Pull the oil pump off and check the backing plate screws--they tend to loosen. Loctite them! Remount the oil pump with new o-ring and ultra-grey or anaerobic sealant. Install new crank and cam seals Make sure you know the proper marks for aligning the crank & cams ("Never the arrows!!!") Oh, and when you put the harmonic balancer pulley back on, use the German method: "Gutentight!" Good luck. Ask questions if you need to . . . and have fun!
