Olnick
    10
Everything posted by Olnick
  1. Welcome to USMB jgruber. If you post your problem in the Older Generation Forum I'm sure someone will have some good suggestions.
  2. Good suggestion. Most starter failures are simply worn/pitted copper contacts in the solenoid--can be fixed relatively easily for just a few bucks.
  3. You obviously have excellent taste in all forms of transportation! What a beautiful creature he is.
  4. New NGK plugs and new OEM wires are always an excellent place to start!
  5. Welcome home! Keep looking--you'll find that "perfect" Subie!
  6. Forget new OEM axles. Call Marshall Wolf at MWE in Denver--his remans are excellent and at a reasonable price.
  7. Ruby Sue sure looks shweet! Makes me miss my '85 GL Wagon. Take good care of her--good luck.
  8. That is a beautiful picture ratbrat. The lighting, the colors, the composition--it's gorgeous! Thanks for sharing.
  9. '90 through '94 EJ22s are OBD-1. I think you'd be wise to stick to '95 - '96 engines--they are OBD-2. Try a search for manifold compatability. Good luck.
  10. Here's a blast from the past with Porcupine73's fine pictorial documentation! http://www.ultimatesubaru.org/forum/showthread.php?t=75009&highlight=coolant+temp+sensor It is a bit of a PITA to access. I replaced mine when I had the IACV out of the car for cleaning--access was super easy then. Good luck.
  11. Welcome aboard Arjen. Your Subarus look gorgeous--how long have you had them? Do you do your own restoration/maintenance? Aloha from Hawai'i.
  12. Welcome aboard joshuare. Check out some of the "Similar Threads" at the bottom of your post. Or try the "Search" function. There's been lots written over the years. Good luck.
  13. Starfox--please post questions like this in the proper Tech Forum, "New Generation Subarus." Thanks.
  14. The '95 EJ22 is non-interference, the '97 would be an interference type. Not all '95 EJ22s had EGR--manual tranny models did not if I remember correctly. So you would need to find an EJ22 from an automatic.
  15. Welcome Ben. Yeah, you found a good "home" here. Good luck with the '96--if it's half as good as my old '95 you'll be a happy camper!
  16. Don't be too hard on yourself--look at the bright side. You fixed the problem and the cost for new parts was . . . priceless! Congrats on good sleuthing!
  17. Welcome aboard Dennis--and congrats on getting back into a Subaru! Folks here are helpful as all get-out so do ask questions. But get familiar with the "search" function too--just about everything you need to do to a Subie has been documented there at one time or another!
  18. Dave--I think the OP is in Huntingdon, east of Altoona. It's spelled with a "d" (but often misspelled with a "t"!)
  19. Welcome aboard! P0506 - Idle Air Control System RPM Lower Than Expected A vacuum leak An air restriction in the intake air path or exhuast A faulty positive crankcase ventilation (PCV) valve Damaged/failed/dirty throttle body Internal engine problem Failed PCM When was your air filter last replaced? Your IACV (Idle Air Control Valve) might be gunked up and need cleaning. New PCV valve might help--and clean out any gunk in the hoses leading to it. Good luck.
  20. Welcome Matthew. You've found a great place here--good info and good people. Suggestion: Put "Columbus OH" as your location in the ID rather than a zip code--helps readers visualize where you are when they respond to you.
  21. Welcome and congrats on the '95 Legacy. I drive one--the EJ22 is a great engine, non-interference and virtually bulletproof! It's OBD-II so you can pull codes with a reader. Definitely do the timing belt, all the idlers and water pump (check ebay and "theimportexperts" for the best prices on these.) Replace the thermostat and gasket (both OEM.) Replace the crank & cam seals (use OEM.) Pull the oil pump--inspect, tighten any loose screws and re-seal with a new o-ring and Permatex Ultra-grey. Replace the PCV valve and clean out the attached hoses. Might want to get new spark plugs (most basic NGK coppers are the best) and wires (suggest OEM.) Change all fluids and filters too. If the car has received half-way decent care before, you should be good to go for quite awhile. By all means ask questions as they come up. But learn how to control the "search" function on here--this board is better than an encyclopedia, you can find everything you need to know to work on your new Subaru. And best of luck.
