Olnick
10
Everything posted by Olnick
Good suggestions above. Yes, '95 is OBD-II. If you pull the codes get the actual code numbers for us, not a verbal description. How many miles on the car? Did you replace the thermostat with an OEM unit or the "exact replacement" Stant? Cheapie aftermarket t-stats can give problems. What plugs and wires did you use? Start by burping the coolant system to make sure there are no air bubbles. Good luck.
Very pretty car. I think I would have stopped him and tried to buy it too!!! Congrats and enjoy!
Agree with GD--flat blade screwdriver has always worked for me. For driving the seals in, a white PVC pipe coupler works well. Just take your seal with you to the hardware store to find the right size. (To keep the seal from going too deep, I took a flat plastic jar lid and hacked a hole in it just big enough to clear the cam shaft, then put it between the seal and the PVC driver. That works on the right side cam IIRC.) And yes, the OEM seals are brown. I was confused--I thought they had been superseded by the black ones, but I just checked with Jason at Mike Scarff and he cleared that up for me! Good luck.
My "new" 99 outback wagon AWD
Olnick replied to jkountz's topic in Meet n' Greet. Your USMB Welcome Center
Welcome aboard, Jim. Yup, they are amazing cars--and this is an amazing place, full of helpful, caring people! By the way--please consider putting your city & state in your ID rather than a zipcode. Thanks. -
Call around locally. Try an auto-electric shop, the starter/alternator repair places that J A Blazer mentioned. Or try Toyota too--they used Denso starters. Then, if someone has contacts, I suggest taking your old ones out and carrying them with you to make a visual match--there are several different styles. I doubt that you will need a new circular plunger contact, just clean your old one up with emery sandpaper. Good luck!
It is confusing--Subaru changed the linkage design several times over the years. But I'm pretty sure yours is just like mine ('95 Legacy L) and that is what is shown in the drawing you posted. You should have the spring (#35043) too. Get under the car and look at the large washer (shown as #35082B)--there's an "ear" with a hole that the spring hooks into. Other side hooks to an ear on the linkage IIRC. I really doubt that you need to replace the linkage. Again, get under the car and check out the condition of yours before you go buying a new one. You probably do not need the shift rod bushings (there are two, one on each side: #35035A)--mine were okay when I checked them. Suggest you use the "search" function here on USMB. There's a lot of discussion from the past that may be helpful to you. Good luck.
Looking good! Glad you're getting started on the clean-up, fix-up, getting familiar with the car. Preventive maintenance is the key to happiness! Strongly second what heartless suggested. Car should be on its 3rd timing belt by now (60k interval). If you don't know the history, by all means change the timing belt, idlers, water pump, replace cam & crank seals, pull the oil pump and re-seal. Also a tune-up. New NGK plugs, new OEM or NGK plug wires, new PCV valve (and clean the hoses to and from the PCV). Good luck--and let us know how it's going.
Yup, new bushings will make a world of difference--makes shifting a real pleasure again! Replacing bushings is a bit of a PITA but well worth it. Many helpful threads about the process in the past, try a "search" and you'll find a lot of good info. Helpful hint: Use "advanced search" and type in your key words (shifter bushings), then select "New Gen forum"--it'll zero in on just what you want. Good luck.
Hi and welcome aboard. What kind of advice? What model Subaru?
Welcome aboard HardDog! You've landed in a good place here. If your Subie is in decent shape I'd say you made a smart buy. I know I love my Legacy L Wagon, a '95. Good engine and handy as heck for hauling stuff. Plus you got the last of the non-interference EJ22s. Good luck--ask questions--and keep us up on your progress.
