Olnick
10
Everything posted by Olnick
so i was wondering...again
Olnick replied to 97ej22's topic in Meet n' Greet. Your USMB Welcome Center
Hello! Hello-o-o-o . . . ? Hmmm, nobody there. Must be Mastic Beach! (Sorry 'bout that, 97.) -
I ain't an automatic type guy so someone correct me if I'm wrong . . . but that's exactly where torque bind happens, in "the center" of the drive train. Specifically in the clutches in the extension housing behind the tranny. That extension housing and clutches can be changed out relatively easily (you don't have to drop the entire tranny.) Try a search, it's been discussed a lot. If you're lucky you might even be able to fix the problem by dressing the faces of the old clutch plates. At any rate, good luck.
Air vent
Olnick replied to JohnKos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Glad we could be of help!!! -
Hi John--welcome aboard. Yup, you've found a great place to hang your hat. Lotsa' good people and a wealth of information here.
How is the "general maintenance" of the engine? As kaki mentioned, new plugs and wires can often make a difference (basic NGK plugs are fine, but be sure to use Subaru OEM wires.) New coil pack probably not needed. New air filter, fuel filter, PCV valve. Make sure electrical connections at spark plugs are tight. Check vacuum lines for weak connections, cracks, leaks. Might even try a Seafoam treatment in the manifold! I assume the CEL didn't come on or you would've mentioned it. Just some thoughts. Good luck.
Shoulda', woulda', coulda' . . . makes no difference as long as you end up in the right place! And I think you realize that you're in "the right place." People here always seem to go the extra step to help a fellow Subaru-er out. Like Don_Quixpunch did in your earlier thread (thanks, Don--that was very nice of you.) So welcome to USMB. Learn, share, enjoy!
Greeting from washington
Olnick replied to Superyooper's topic in Meet n' Greet. Your USMB Welcome Center
Welcome Tj. I think you found the right place here! -
Yes, they do fail once in awhile. You might try unplugging it and cleaning the connector--see if that helps before buying a new sensor (around $30 IIRC.) To find it, look from the right (passenger) side at the firewall end of the engine, down under the intake manifold. It's hidden down there under the PCV tubes and the IACV valve. It's a brick red color conector. There's a pic in this thread that might help: http://www.ultimatesubaru.org/forum/showthread.php?t=84323&highlight=coolant+temp+sensor Good luck.
