Olnick
    10
Everything posted by Olnick
  1. Go talk to him. let him know how displeased you are. Unless you flat out demanded that 60k timing belt change he might try to do right by you down the road. If he's a smart businessman, that is.
  2. Well, you should use whatever oil you are comfortable with provided it is properly certified and meets the requirements listed in your owner's manual (also listed in the Haynes manual.) As far as a specific recommendation, some of us happen to like Red Line 75W90ns. I use it in my '95 Legacy tranny. The topic has been discussed over the years--use the search function and read what people say. Good luck.
  3. Is there anything else we can help you with? j/k--glad you solved the problem (in under an hour, no less!)
  4. How does the car's handling on the road feel to you? Does it wallow or bounce a lot? Does it feel at all unsafe to you? If so it'd probably be wise to replace them. And yes, KYB GR2s seem to be widely recommended for Subarus and other Japanese cars.
  5. Definitely start with what the code is telling you. Pull the knock sensor and check it for cracks. Also clean the electrical connector so you know you have good contact. Good luck.
  6. Welcome, fixit72. Please post your question in the New Gen forum.
  7. Discussing oil/additives is like discussing politics or religion--everyone has their own opinions and choices! MMO is a pretty good solvent, it'll loosen up crud in your oil system. But in my mind it can't do that and be a good lubricant, if it can be a lubricant at all. It has been talked about for years: http://www.ultimatesubaru.org/forum/showthread.php?t=36013&highlight=marvel+mystery Today's approved motor oils are very well engineered for the job they're expected to do. I'm sure Valvoline is an excellent product and will protect your engine just fine. Personally, I use full synthetic and love it. Sorry, can't help you with the radio/deck. Hey--looks good in the Craigslist pic!
  8. Congratulations! If it's in decent running shape you got yourself a good car. The EJ22 is a great engine and, fortunately, non-interference. By "Marvel" I assume you mean Marvel Mystery Oil? It's good stuff for cleaning out oil passages but I would NOT run it regularly. Stick to a good quality motor oil only. Your engine should run just fine on standard gasoline. Don't waste your money on a higher octane than you need. Good luck and happy driving. Post us a pic when you can.
  9. No guarantees but it's a possibility. When the ECU gets poor/no temp information it will default to open loop (I think) and cause the engine to go all wonky. It's about $30 IIRC. Or at least it was a few years ago! Replaced mine when having some rough running and stalling problems and that pretty little EJ22 ran like new. And here is a two-for-one trick: Take your IACV for a thorough cleaning, while it's out you have a clear shot at replacing the Temp Sensor! Good luck.
  10. Welcome shlbsnake. Please post your question in the New Generation forum.
  11. Love your thread title! Car looks to be in great shape. How about a peek under the hood?
  12. Amen to that! A longshot: Engine Coolant Temp Sensor need replacing? Question: Did you use NGK plugs & OEM wires?
  13. You'll get a lot more response if you post this question in the Old Gen forum.
  14. Just noticed this in your original post. Are you in Australia? Might help if you put that in your location information.
  15. Nice job, Fairtax4me. Lookin' good and the nighttime light beam shots are quite impressive. Thanks. Wonder how many Subie owners will be out with sandpaper, polish, etc. this weekend?
  16. Which leads to the question, if I were to buy a blue RS . . . would it rain?
  17. Welcome, poomwah. Actually '90 thru '96 is a great choice--excellent EJ22 engine, non-interference and generally solid. But they are getting older so just shop carefully. Good luck.
  18. Feeding the Seafoam in through the PCV hose gives a better distribution. Just make sure the hose is cleared of oily gunk buildup before you do it.
