![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Olnick
10
Everything posted by Olnick
Google Kelley Blue Book (KBB) and Edmunds online. They both have calculators to determine used car values. KBB is basically a dealers' tool--their values will usually be higher. Edmunds claims to show "True Market Value" calculated from actual sales. Between them you can get a feel for used car pricing.
- 10 replies
- negotiating
- price
(and 1 more)
Tagged with:
Welcome to USMB, Macca. If you'll post your questions in the New Gen forum you're more likely to get technical help. Good luck.
Welcome aboard, CB--you're a very lucky man: 1) You found the USMB, 2) You own a Subaru Diesel, and 3) You live in Ireland! The USMB is a fantastic source for "all things Subaru." Unfortunately we don't know a heck of a lot about the diesel models, other than the anecdotal and theoretical--they won't let us have them here in the US! But I'm sure there are enough commonalities that you can glean some helpful information. Post any specific technical questions here in the New Generation forum. Ireland--ahhh, the beautiful Emerald Isle! I have roots there (doesn't everyone?!!) So last summer we took our daughter and her family there for a short visit. Fantastic--lovely countryside and wonderful people. My only concern was that our beautiful 6 year old granddaughter, who has flaming red hair, might not be allowed to leave the country!
As you eliminate the likely sources of oil leakage (cam & crank seals and valve cover gaskets) and when the underside of the engine is cleaned up, you should be able to narrow down the location of remaining leaks. A separator plate leak would show up under the bell housing at the rear of the engine. Have fun and keep posting your progress!
Welcome to the USMB, Fatenarr. How long since the car had a basic tune-up? Since the last timing belt? Is it an AT or MT? I wouldn't jump into headgasket replacement until you have proof they're needed--EJ22s rarely have HG problems. Is there excess air in the coolant system? Are there bubbles or oily bits in the coolant overflow tank? Start with new timing belt, idler pulleys, check the tensioner.. Check the oil pump, tighten the screws on the back of the impeller, re-seal with new O-ring and sealant (Ultra Grey or anaerobic). Do the crank & cam seals, camshaft O-rings and valve cover gaskets. New water pump with OEM gasket. Then give it a tune-up--new plugs (NGK) and wires (OEM or NGK), new air & fuel filters, check/replace vacuum hoses & PCV. Only other common oil leak culprit would be the oil separator plate on the back of the engine block--that would require pulling the engine or dropping the tranny to access. After that, clean the engine block and keep an eye on the headgasket seams for a period of time--see if they are actually leaking. Good luck & keep us up on your progress!
Also consider Mizumo Auto--I've bought two kits from them and have been pleased. $165.99 + $35 FedEx shipping. Includes timing belt, Aisin water pump with proper metal gasket, idler pulleys, crank & cam seals (with 2 extra cam seals--funny story!) Do you really need a new tensioner? The old (horizontal cylinder) ones are pretty durable. Google ebay mizumoauto and check them out. Sorry--for some reason I can't paste a link on here.
Looks good, sounds good and the price is probably fair. Where did you find it, on Craigslist? How long has it been listed? Remember that's not a hard-and-fast "price"--it's what he'd like to get for it. If it's been up for awhile he may be more receptive to reasonable offers. I'd start at $4k and see what happens. Good luck!
