Olnick
10
Everything posted by Olnick
Amen to that brother john! I faced the same over-tight problem on mine awhile back. Set up the car jack under the 1/2" breaker bar and slowly cranked away--worked like a charm. Use small blocks of wood to make sure the jack is absolutely perpendicular to the breaker bar and adjust as necessary during the process. Good luck.
Sounds like the solenoid may be bad. Might want to remove the starter (it's easy, one bolt and one nut--at least that's how it was on my EJ22) to check the solenoid's plunger action and condition of the contacts. If it's just the contacts that's a cheap and easy fix. Or if you have to, replace starter and/or solenoid with a reconditioned one. Personally I would avoid a chain store rebuilt starter. Check around for an auto-electric shop locally--ask local mechanics who they use. Good luck.
I wish you would stop making that generalization every time someone mentions an overflow tank, nipper. Mine is so clean you could drink out of it. To clean the tank, remove it from the car and partially fill with warm water and detergent, stuff a small piece of rag in it and shake vigorously. Then take a length of coathanger wire, form a small hook on the end and use it to push the rag into the corners to scrub with. Hey, stop by for a drink sometime!
Ultra Grey is not anaerobic however Subaru approves it as a substitute for the original sealant, which was anaerobic. Loctite comes in different strengths denoted by color on the packaging. You'll want the blue (medium strength.) But I'm just spouting this stuff from memory and could be off or even wrong. Still suggest that you use the "search" function here on the USMB--there's a treasure trove of facts and helpful hints from the past and can answer all your questions--even those you don't know yet! Good luck and keep us posted on how it goes!
IIRC Permatex Ultra Grey is approved for sealing the oil pump to the block. Also don't forget a new o-ring for the oil pump. Haynes manual does show a water pump gasket and a thermostat gasket too. Get genuine Subaru parts for those--and for the thermostat itself. Check your crank and cam oil seals for leakage. It's a good time to replace them. And the cam shaft o-ring on the left (driver's) side. Check all the timing belt idler pulleys too. The cogged one nearest the water pump is usually the first to go. Doing all this while you've got the front end open is a lot easier than having to go back in later! Good luck!
Gee, john, you're human! So am I. Did almost exactly the same thing and had to backtrack several steps to correct it. Guess the lesson is don't rush, re-read the instructions every once in awhile and stop to mentally review every so often. What a thrill when I finally cranked the engine and it purred. (But am glad I kept my day job!)
Ah, the old saying "search is your friend!" Tons of information on here--got me through my first timing belt change. Here's a link to start: http://www.ultimatesubaru.org/forum/showthread.php?t=21715&highlight=timing+belt+endwrench Just go to "search" (up top) and type in timing belt. And do read the Endwrench and other articles referenced--very helpful. Good luck . . . and axe questions!
