Olnick
10
Everything posted by Olnick
Uh, just to put my mind at ease . . . when you say "tranny fluid" you do mean gear oil, right?!! Haynes states 3.7 qts of API GL-5 SAE 80W-90 (although I used Red Line 75W-90ns and love the results.) Just put three-and-a-half quarts in, let it settle, then keep checking level with the dipstick as you top it up.
Cam seals
Olnick replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Maybe this is too obvious but . . . while you have the front end opened up do a thorough inspection of idlers (especially the cogged one), tensioner, water pump and oil pump. Timing belt too. It's a good feeling isn't it? -
If you really want to see a difference put the samples in small/narrow glass jars, like an olive jar or babyfood jar. Makes you feel good when you hold them up to natural light and see how dramatic the difference is. I had a couple of jars in our dining room hutch for over a year ('til my wife caught me.)
Yes it does sound like your bushings are shot. Parts needed depend on the year/model of your car--Subaru made several changes over the years. I'd suggest you get a Haynes manual and look under "Shift lever--removal and installation," there's an excellent blow-up drawing there. Then slide under your car and study the linkage, especially the "boss joint" that connects the rod from your shift lever to the rod stub on your transmission--that's where the worn bushings usually are. Search here on USMB for shifter bushing threads, there's pretty good information and links. You can start with the "Similar Threads" listed at the bottom of this page. Finally, if you want to talk to someone about the parts you need, I highly recommend calling Jason at Mike Scarff Subaru in Auburn, Washington (866-528-5282)--very knowledgable and great prices. Good luck, and when you have specific questions come back here and ask.
