sub_dont_touch
Everything posted by sub_dont_touch
Went and got a spare fuel pump housing, swapped over the gas tank gauge meter thing. Before putting my fuel pump on, checked for power and there was 12v! So with my hopes up, put the fuel pump on, put the assembly back in the tank, tried starting my car but still not starting. To me this must mean that the fuel pump is bad?
The wires and connections are all ok. It's weird because it can only be the ECU now really. Or the fuel pump itself but I doubt it. Have checked the wiring and have swapped the fuel relay with a relay that was next to it on the same bracket. How do I run power straight to the fuel pump so it's running all the time? I know it's dangerous to drive around on. BUT this would tell me if I need a new fuel pump or not, am I right? Something about bypassing the relay or something?
1994 ej18 impreza gc6. (right hand drive) Is the green plug quite small? I see two green plugs unplugged next to each other. Also with the fuel gauge, when the car is turned off should the needle go right back down to empty? Or does it stay on how much fuel you have even when off (might have broken the fuel floater sensor thing)
just a question about closing the tank again. I put the assembly back in. I'm not sure if you need to do anything special or not but now my gas gauge says I have more than half a tank of gas. When the car is turned off I have quarter. Also is there anything I need to do to get fuel pumping again? (my car is not starting, thats why I am opening the tank etc) thanks
Hi, I see there are four black relays in the engine bay fuse/relay box. Are these the only relays or is this a big round silver relay somewhere? Reason is that I need to swap a relay with the fuel pump relay in my 94 impreza to see if it bad or not. I pulled out a black a/c relay and tried plugging that in but I'm not sure if this is right or not because my car still didn't start.
I have my brother turning the key on and off to the on position while I check for power. There seems to be no power after the connector plug and down to the fuel pump. The fuel gauge wires have power tho (around 0.5v) and they are using the same plug. Just tried connecting power straight to pump, sounds like its working fine, a whizzing sort of sound.
I've removed the fuel pump assembly. Everything looks fine. No bad wires or connections. I tried connecting the connector plug with the unit out. Tested for power at the terminals on the fuel pump and only showed 0.01v (turned to on position), which is weird as there was 11v at the connector plug. how do i connect power straight to the pump? Wires from battery to pump?
Hi, I removed my fuel pump assembly from my 1994 EJ18 Impreza. It looks in good condition to me, but who am I to tell. I want to know if there is any way to tell if it needs to be replaced or cleaned? And how would I clean it? I also checked for power at the fuel pump itself with the connector plug in. There was 0.01v at the pump. but 11v at the connector plug. this is no damage to the plug or wires at all.
