- 81 Brat SubaRude
- 81 Brat SubaRude
81 Brat SubaRude
- 81 Brat SubaRude
Subarude has been neglected most of the winter needs major brake work. A guy just pulled into my driveway today with a car trailer and tried to buy her, I just told him she’s worth more than money. But it’s shameful of me to let her sit so I need to make room in my crazy life to get her back to running and stopping asap- My Free 86 wagon
- More rust repair 81 Brat
Here is a nickels worth of advice. When welding sheet metal use a spot weld and random places to keep the heat from warping the patch. It will be a stronger weld in the end. Great project cheers, Shane- brat stuck in 4wd
Sometimes my brat feels like I’m stuck when parked. It shifts out of 4low easier when I am slowly moving let off the gas and shift clutch in of course. Or reverse and shift out clutch in. With out more information hard to tell. And el Freddo answered you original question perfectly.- Brat 1800 Bodyshell question
Unless your building a beauty queen removing rear fenders is a time consuming expensive task. My Brat is a driver I remove taillights and spray some tri flow in there a couple times a year. My rust hasn’t grown since I bought her.- Greetings from Idaho
There are a few of us in Idaho. Welcome- New Member from Socal!
Love your subi welcome to the pack.- What do you use to flat tow?
I have flat towed my Brat from east coast to west coast several times with no issues. Stock bumper with a 1/2 inch by 2 inch flat bar full length on inside of bumper tow bar is bolted to this. All nuts have been tack welded so they don’t back off.- 1979 Brat w/ Weber Carb issues
I would start over. I mean take a breath/ have a beer. +1 on fuel pressure gauge. Pull the weber off the car, clean the base plate. Rebuild the Weber, kits available from $30 up. make sure it has accelerator pump ect and not just gaskets. I soak my old carbs in cleaner available at any parts store in gallon size. Take your time take photos and notes when tearing it apart. (I do this because I get interrupted and may be weeks before I can continue) Check for vacuum leaks when you get it back on. Crazy stuff happens when you rebuild motors. I use Diethyl ether to check the base plate and vacuum ports for leaks. Quick shots don't get all wild You will get the fun Brat back into trouble faster than a body swap Guaranteed !- Opinions on Leaded Fuel? EA-71
In Idaho you can get super with or without ethanol. I do agree with GD after time all goes to tar, but non-ethanol in my brat a year and didn't turn to varnish.- Opinions on Leaded Fuel? EA-71
I have only run super non- ethanol in the wagon and the Brat for the last three or four years now just for that reason. I am able to run a little more timing, and even when they sit for months I've had zero issues starting. It's worth the 30 cents a gallon upcharge to me.- Seat belt rebuild?
Update: did this fix work? there is a guy here in my hometown that bought a parts Brat I could see if he will sell the belts. PM me - 81 Brat SubaRude
