3
Everything posted by ironworkerboomer
I know if only life would take a break we could all catch up.
Subarude has been neglected most of the winter needs major brake work. A guy just pulled into my driveway today with a car trailer and tried to buy her, I just told him she’s worth more than money. But it’s shameful of me to let her sit so I need to make room in my crazy life to get her back to running and stopping asap
free wagon is now retired as daily driver has served me well. My son is going to make her into a camping rig. I’ll update photos as we progress
- 17 replies
- 1
More rust repair 81 Brat
ironworkerboomer replied to TXJayhawk's topic in Historic Subaru Forum: 50's thru 70's
Here is a nickels worth of advice. When welding sheet metal use a spot weld and random places to keep the heat from warping the patch. It will be a stronger weld in the end. Great project cheers, Shane -
Unless your building a beauty queen removing rear fenders is a time consuming expensive task. My Brat is a driver I remove taillights and spray some tri flow in there a couple times a year. My rust hasn’t grown since I bought her.
Greetings from Idaho
ironworkerboomer replied to 2002 FORESTER L's topic in Meet n' Greet. Your USMB Welcome Center
There are a few of us in Idaho. Welcome -
New Member from Socal!
ironworkerboomer replied to NoStyle's topic in Meet n' Greet. Your USMB Welcome Center
Love your subi welcome to the pack. -
1979 Brat w/ Weber Carb issues
ironworkerboomer replied to sbrats79's topic in Historic Subaru Forum: 50's thru 70's
I would start over. I mean take a breath/ have a beer. +1 on fuel pressure gauge. Pull the weber off the car, clean the base plate. Rebuild the Weber, kits available from $30 up. make sure it has accelerator pump ect and not just gaskets. I soak my old carbs in cleaner available at any parts store in gallon size. Take your time take photos and notes when tearing it apart. (I do this because I get interrupted and may be weeks before I can continue) Check for vacuum leaks when you get it back on. Crazy stuff happens when you rebuild motors. I use Diethyl ether to check the base plate and vacuum ports for leaks. Quick shots don't get all wild You will get the fun Brat back into trouble faster than a body swap Guaranteed ! -
Opinions on Leaded Fuel? EA-71
ironworkerboomer replied to Subasaurus's topic in Historic Subaru Forum: 50's thru 70's
In Idaho you can get super with or without ethanol. I do agree with GD after time all goes to tar, but non-ethanol in my brat a year and didn't turn to varnish. -
I have only run super non- ethanol in the wagon and the Brat for the last three or four years now just for that reason. I am able to run a little more timing, and even when they sit for months I've had zero issues starting. It's worth the 30 cents a gallon upcharge to me. -
Seat belt rebuild?
ironworkerboomer replied to Grisezd's topic in Historic Subaru Forum: 50's thru 70's
Update: did this fix work? there is a guy here in my hometown that bought a parts Brat I could see if he will sell the belts. PM me -
Seat belt rebuild?
I pulled all the slack out sprayed the bejeezis out of the roller mechanization with contact cleaner then worked the belt in and out put a few drops of tri flow lube and they put started working again. These were the jump seat belts and they were basically froze when I started. Hope this works as well for you. -
78 GL and 79 DL Brats
ironworkerboomer replied to Zags's topic in Meet n' Greet. Your USMB Welcome Center
I love the Brat. Welcome to the party. -
wagon wheel center cap tricks or tips?
ironworkerboomer replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A couple of dabs of clear silicone and you will never lose a cap. -
1978 brat firing order
ironworkerboomer replied to DPM's topic in Historic Subaru Forum: 50's thru 70's
1978 brat trany wont stay in 4WD
ironworkerboomer replied to 80brat's topic in Historic Subaru Forum: 50's thru 70's
My old 78 brat started that and it cost me a transmission rebuild. The gears were just wore out. This was years (decades) ago when you could still get them rebuilt. -
Mechanical fan
ironworkerboomer replied to Movinasfastasican's topic in Historic Subaru Forum: 50's thru 70's
I would go with an electric fan it moves more air and is two wires power and ground. -
1980 GL Wagon "My quest for something different"
ironworkerboomer replied to Rallyru's topic in Members Rides
What were the longer struts out of? and what snorkle did you use? it fits nice. Great build -
I'm working in Boise Idaho, job was supposed to be gravy 4-10's weekends home. It ends up 6-10's and a nightmare. Wife and son drive over to see me, and Baja throws a fit. Wife notices temp warmer than usual stops lets it cool down low antifreeze. oil change less than 100 miles ago all fluids checked. She fills it continues on. They get here tells me the story, I check it and low again. No water in oil so yea me. Next day she takes to private shop $$$$$. then to dealer shop manager says "Subaru should have recalled these POS gaskets". So long story short fixed the head gaskets, serviced the air conditioner, timing belts, and tensioners for the same price as private joe fix your car. And gave us a 2017 Crosstrek for the 5 days Baja was in the shop. I just wanted to share this experience because dealer rip you off stories are the norm. They have my future business even though they are 5 hours from my house.
