About Slegacy96
- Birthday August 13
Contact Methods
Website URL
http://
Location
Towson
Occupation
Behavior Analyst
Biography
Like Legacy's
Vehicles
2015 WRX, 2017 Outback 2.5i
Slegacy96's Achievements
Subaru Fanatic! (6/11)
11
I've combed the web and posted this on NASIOC already, but I can't seem to find a solution. Hoping there are some ideas here. It's been awhile since I've visited. I have a 2015 WRX. My tire inflator blew a fuse, which has happened several times before and typically I just replace the fuse and go about my business. However, this time my HU, trunk light, interior lights, and keyless entry have stopped working. The interior power door lock switches work just fine and the car alarm is set off when I unlock the car with a key, but the car doesn't beep when you lock it and then close the door. The keyless entry and trunk light are on fuse 15. I've checked all of the other fuses and everything looks in good order. I've checked relays. I've tried disconnecting the car battery and still no luck. I've seen other posts that point to the "back-up" fuse as being the problem. To clarify, that doesn't seem to be my problem. The fuse is good. There has to be something that I missing. Last
I finally broke down and took the car to Subaru. They informed that the timing was off when it was put back together and there is nothing that can be done for the car, other than trash the engine and put a new one in. What I don't understand is that if this car has an interference engine, botched timing would result in more than a loud ticking sound, would it not? Other than the noise, the engine runs great and the gas mileage is the best that it has ever been. I don't understand.
