Location
Snohomish, WA
Vehicles
I Love My Subaru
Recent Profile Visitors
Kyle691's Achievements
Advanced Member (3/11)
10
They have relay unit that controls the fuel pump when the car is running. If the relay is bad it won't turn the fuel pump on. I had to wire the fuel pump to come on with the key in one of mine before. I've also had the rear fuel filter completely clogged.
EA81 Rocker Arm Inspection and Reassembly
Kyle691 replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Service manual says Clearance between rocker arm and shaft:.0005-.0020 Inner diameter of rocker arm:.7093-.7100 Outer diameter of shaft:.7080-.7088 I know the location of the spring washers on the shaft is important. Not sure if the direction is. -
Moustache Bar Bushings?
Kyle691 replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This might help. http://www.ultimatesubaru.org/forum/topic/146014-bushings/ -
webercarbsdirect-Have i been burned?
Kyle691 replied to 87subbomber's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did the same thing about two years ago. The only issue I have had so far is the choke screws backed out. Which could have been loose when I received it. So I took it apart and used some medium loctite to hold them in and haven't had a problem since. -
Spring meet (nothing big) Edmonds WA ?
Kyle691 replied to one eye's topic in Meet n' Greet. Your USMB Welcome Center
How late are people going to be there? -
wrx seats in a 2nd gen brat?
Kyle691 replied to d8usti5n's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I installed RS seats in my brat. If you use the brat seat brackets the seats sit lower to the floor. Not to sure if you gain leg room. If you use the seat brackets from the original brat seats it isnt that hard to do and seats sit low. Cut a couple pieces of steel and drill some holes. But if you modify the RS seat brackets to work the seats sit pretty high. This was also a bit more work. -
Help me hook my ea81 back up after engine swap
Kyle691 replied to andrsn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did you get this solved? -
Pretty cool! Have any other pictures of the brat? Did it come with the cowl on the roof?
Leeroy is correct about the ea81 not mounting to the top Mount starter transmission. I just did this swap over the weekend and had to use the ea81 transmission because they do not line up. Also depending on what type and year ea71 car you have there is a couple other little things that need to be changed.
Motorweek's review of the 82 BRAT
Kyle691 replied to subarubrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That was awesome. Wish my brat moved that well. -
Should I buy this rotted out BRAT?
Kyle691 replied to jmoss5723's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd give you 50$ for the roll bar. -
Did you have a hard time putting that on? Any pointers?
Pics would be awesome. I have been debating on this for a long time haha
