frogstar7055
Everything posted by frogstar7055
  1. I dunno,looks better now than before the wreck to me.
  2. Was a lot of work,had to use some equipment at my work and can't do that all the time. Jackson Rally over on dirtyimpreza.com makes a 1" lift and is supposed to be working on a 2" kit as well.
  3. 4 foot! I must be nutz:banana: I asked a lot of questions of our Aussie brothers and trigged it out myself and came up with 6mm of offset. Worked but not quite enough,had to put camber bolts in rear. Should have went 7mm. (3.5mm per inch of lift)
  4. You GOTTA post vids of that in action when your done.
  5. I think that would fail in a spectacular fashion in pretty short order. I've had the same idea as Uberoo and monstaru but I think a pin thru the shaft would create a weak point that would fail eventually. I think it would be a better idea to retrofit a locking hub from a regular 4x4 with a welded diff. Then you could just disconnect the hub for on road use. I know,lots of backyard engineering but so would a disconnect on the shaft.
  6. My ride, Dirty(usual state) Now....... 2001 Forester with 2004 engine 2" lift (homemade) 2008 FXT struts and springs (excellent freebie) Cold air half snorkel (homemade) Front bash plate (homemade) Rear diff protector (homemade) TB spacer (homemade) Yokohama Geolander AT-S 225/70 15's (store bought) Hella 500 driving lights (store bought) Valley roof basket (store bought) Strut braces (cheapy e-bay) Underhood grounding kit (homemade) XM radio (because terrestrial sux!) In the works....... 4EAT lock switch (got relay and resistors just gotta do it) Rear LSD Hitch and receiver mounted winch (got both just gotta put it on) Bumpers(homemade) need better approach and departure angles Roof mount the spare (homemade) Duel/second battery in spare well for acc That's it so far.
  7. That would be perfect with 2" lift. Very freakin' cool:grin::grin:
  8. Not looking to mod it that much (although I've considered it). Really want to retain as much of the drivetrain as possible,just want to take it as far as I can. Thought about welding the rear diff and fabbing up a wheel locker on one side so a rear wheel could be disconnected on street (still considering that one).
  9. I've got a 4EAT and they don't make a front one for it. Really just want a lsd in rear,just can't make up my mind which way I'm gonna go.
  10. Who makes a locker for the R-180? I've run across a couple of them in my wanderings,should have picked one up.
  11. He asked about a locker. R-200 is the ONLY way your gonna put a real locker in a Subaru. Nobodies gonna make one for an R-160,too weak and not enough interest to produce one. And as for doing a R-200 in my Forester it would be easy for me except for the $$$$$$$$.
  12. More than a thousand miles and A-OK. In future may make 4' strut top spacers and go 2" on everything else. More involved than that I know but I like making mods.
  13. It's easy,retrofit an R200 with an ARB e-locker. Fab up new mounts and shafts. Install and flick the switch. Only around $1500-$2000 (guesstimate).
  14. Ya I just want to run it in the rear as well. Think I'm gonna do this.
  15. Anybody currently using one? Pro's,con's,general feedback from someone who's used this. pinister used it but he hasn't posted for over a year.
  16. PB blaster is your friend. Never use a "12 point" on hardened bolts,always use a 6 point.
  17. I own an 01 and an 08 and love them both. I to believe the HG problem is blown way outta proportion but I would definitely do the timing belt(water pump and idler while your in there). That being said the issues you stated make me feel around $4000 or so would be a better price.
  18. Some pics from Hardrock OHV park in Ocala FL. The Forester made it's bones today,did everything I tried and I climbed almost every hill in the park. I've never felt so confident of it's offroad abilities. Vids. Was to much fun,can't wait to do the 4eat lock mod and go back.
  19. Those are not the AT-S all-terrain tires. I have a set of the AT-S's 225/70 15 on my 01,great in rain and very good off road.
  20. Figure if it looks like it's gonna wear them out prematurely that's what I'll do.
