codytotheh
Everything posted by codytotheh
Car Stolen... Seattle Area
codytotheh replied to audio_file's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sucks im so far away, but seriously; how often is there a group of people who will watch each others back like this. Makes me even more proud to drive a subaru. Best of luck man, i hope you get your car back and i hope the *********************s, drop their soap, repeatedly. -
Yeah that is music to my ears. I will definitely pull everything brake related, and maybe once the michigan 37 degree rain / mist fest ends ill have the motivation for the M/C swap which i suppose wouldn't be horrid if it matches up the same. and then i still need to decide if im gonna buy the rest of it + another XT6 for $500 - what i pay for the rims and brakes Just curious is there any other easy stuff i can yank and swap fer fun.
Well after a long cold winter without owning an 82 roo, I'M BACK!! Picked up a 1988 gl from Nevada so it has less rust than most Michigan gl's. EA82 F.I, D/R Five speed. :-D needless to say im ecstatic issues: -One bent rim, 3 shot tires 1 damn near shot tire -broken wheel stud in back left drum. I am wondering if: a)The rims form a turbo xt4 will work (i had a set on my turbo gl10 but that had discs) how much of a bear it would be to just yank the brake assemblies off the back of the XT and put them on my GL. ( i searched but most of the writeups i found were geared twoards the ea81s, or brats) If those are relatively easy i will have my car on brand new tires, with brand new brakes by monday ~!!!
As the title says i have a 95 5 speed sedan, i keep staring in to the lovely eyes and grill of an OBW at the scrapyard...... looks the same, does anyone know 100% if this is a direct bolt on to change bumpers ?? I would usually just buy it but they want damn near 200 for it and im not prepared to spend that unless im sure.
no idea why just a couple days ago my car decided to throw me a new curve-ball -88 gl-10 turbo swapped 5 spd pb. when i turn off the car, the driver side not headlight but corner light stays on, as well as the pass. tail light. as an added bonus i've blown 5 fusible links since this started, any ideas where the gremlin may be hiding??
well i searched around here and haven't found a whole lot on this subject. i don't like my digidash, and my originally auto wagon is now a 5spd so half the stuff is useless to me. is it possible to go to analog ???
i have ran plenty of water / coolant through this readiator trying to diagnose this, including two full flushes, get great drainage. when i took out the stant super crap. one side of it water, other side coolant..... ill try the dealer tommorow i really hope they have a thermostat in stock. if no luck after that im going the rad, then waterpump then hand grenade route till something makes this move.
Just got a legacy sedan 173k on the clock. ej22. 5 spd. It was overheating no pressure in upper hose lower hose was cold. so i changed the thermostat and fluched the rad. still doing it, no heat when idling it doesn't overheat get on it for a second and temp goes right up...... im dumbfounded, still hot upper hose, cold lower hose. when i drained it from the rad. flush stuff it was warm but not hot at all..... ideas on what this could be, no smoke no coolant in the oil.
ebay acl race bearings(opens up your revving abilities a bit more) - 80 bux shipped sti pistons - 50 ish right now on there (not sure if they'd work right you'd have to check the numbers didn't find any normal pistons on there. if you do it please post a ton of pics and a how-to i have an ej22 that might be needing a rebuild soon..... GL
