coldfusion21
About coldfusion21
- Birthday 08/09/1986
Location
Portland, OR
Occupation
Cnc machinist
Ezboard Name
Coldfusion21
Vehicles
1990 legacy wagon auto
coldfusion21's Achievements
Advanced Member (3/11)
10
The power wire feeding the fuses was totally the issue!! Thanks a lot for that hint. Once I started poking around the fuses it was pretty obvious, wire was heavily corroded and had severally overheated. Gonna try and find a suitable donor tomorrow at the pick n pull, along with a faulty taillight harness. Thanks guys, really appreciate the help and hints.
Bulbs are not burned out (or rather they've been replaced with new with no change) It's an auto. I guess my question is what actuates the switch? And it sounds like what I thought was two switches is actually one assembly with multiple contacts? Sorry for all the questions but I don't have access to the car currently and once I do I wanna be able to get to the bottom of this ASAP. Dealer quoted 140 for a new one so I wanna be sure there's not something else going on before I order that.
Sorry to bump such an old thread but I've got a similar question. It looks like the switches for both the backup lights and neutral safety are internal to the transmission? I have a 90 legacy with no reverse lights and intermittent neutral safety starting issues (moving the shifter around gets it to start) could this be a power/ground issue to both switches or are they just both failing? Car has 300k so wouldn't be surprised if they are just worn out.
I didn't see the other response thanks for reposting that. I'll have to carefully examine those wires. As for your reply Ivan: You think all those things went bad at once? This was a turn the car on and one day "x" didn't work sorta deal. Blower relay was checked and is good, blower is getting 12v (signaling the relay is working as well) Blower works well when supplied with 12v outside the car Will check hazards in the am and report back! Thanks again for all the help, I'm gonna get this figured out!
Bump. So far its been a year almost and I'm ready to fix this for good. Plus it's getting cold again! So to recap, no blower, no horn and the shift lock don't work, all stopped working at the same time. I figure it must be a bad ground or a broken wire or something. Blower motor works fine when powered outside the car and is getting 12v at the connector.
I have a 1990 legacy with a confusing issue. Over the last 18 months the blower would stop working for a couple days to a couple weeks and then start working again, usually before I had a chance to investigate. About two or three times ago I (10-12 months ago) it was non working long enough for me to pull the blower. It was full of leafs and debris. I cleaned it inside and out and bam worked again. For a couple months. Around this time I connected the blower issues to the shift lock issues (have to push shift lock button to shift) to a non working horn. About a month ago it all stopped working again and this time it seems to be permanent. Blower is clean and when jumped to straight 12v, it works just fine. Blower connector is getting 12v whenever fan is on, yet the blower doesn't work. Relay has been bypassed with no change. I have some wiring diagrams off alldata but they are hard to follow and I'm having trouble making use of them. Fuses appear all good. I can't find any link between the three functions, so is this just bad luck or is there something that all these functions share? I know someone out there has my answer, thanks for your guys help in advance! Jared
Im gonna bump this. 90 legacy wagon, auto. Blower will stop working, along with the horn and shift lock. Every time one stops working they all stop working. I didnt think the shift lock was related and pulled the blower motor out and cleaned it and replaced, all was well for a month or so. Now its been 3-5 days of mostly not working and i discovered the horn is not working either. Thoughts? Thanks for any ideas.
awesome info guys! im gonna hunt down a set of rails and swap to newer injectors for sure now! Can someone take a pic of a old style rail next to a new style? I wanna make sure i got the right parts. I just bumped another thread on this same topic, maybe i should post a link to this thread as well for anyone that goes looking in the future?
sorry to bump an old thread but this seemed like a good place to ask about first gen legacy injector differences. I have a 1990 legacy AT. I need to source some injectors for it, but have been told that 90 injectors commonly fail and are specific to that model year only, hence making them rare on the used market. I wanna know what other injectors will work with my car, including the AT vs MT thing. i went and looked up some injectors on rockauto and noticed the AT injectors were almost double the MT ones... If other injectors will work i will likely source a good used set, hopefully from mountain tech.
Pictures, awesome! Yes it is auto, edited the original post to clarify. So the tailshaft housing comes off and that contains the clutches? It sounds like you sourced some used ones off a tranny you had around, can they be had new? Is that the duty "C" solenoid everyone speaks of? Does the tranny puke all of its fluid when doing this? I hate auto tranny fluid, looks like i'm gonna be bathing in it doing this job. Sorry for all the questions, just trying to figure out all the details before i get knee deep.
I have a 91 legacy automatic that i've been driving for a while, done a few rally cross events with and do some logging road exploring with as well. Recently on a trip into the woods i wanted to test my traction on the gravel up a real steep slope. Imagine my surprise when only one front wheel was spinning. I tested this out on some other areas and it seems like my awd car is now a fwd car. Question: Is this the result of heavy wear on the clutches that transfer power to the rear? The car has 252k on it and i drive it hard, so i wouldn't be shocked if this was the case. No, the FWD light wasn't on, just so no one asks. If it is the clutches are these an item that can be replaced separately? Can i do it without pulling the tranny? Its not something i'm concerned about right now, but rally cross season is quickly approaching and i would like to fix it by then. Thanks in advance. Jared
