Everything posted by Txakura
nice price
3 Subarus had to die to get all the console pieces together, later I'll work on getting the colors to match. For now I'll just enjoy not having to stare at an unfinished dust boot. Yes, that's my s/r shifter on the d/r stuff... couldn't part with the switch
You're good to go. Someone may have already dealt with it. Now get 'em on there so you can enjoy them
Need Help in SW WA for '86 AC
Txakura replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"What a lot of great information! Thank you for taking the time to write this up, and for putting it in an easy-to-follow manner." ditto -
brake bleed screw goes to the back, line fitting to the front - speaking of which, did you get the metal brake line too? the line is a little different from the rubber hose connection on the trailing arm to the caliper vs. to the drum, also the drum fitting threads in, the caliper has a banjo bolt
Gas Mileage Meter for Older Gen Soobies?
Txakura replied to Davalos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
because he wants to see a real time display of his current consumption -
Shock fluid replacement for stiffer damping
Txakura replied to presslab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wasn't meant as a serious slam, just a tease, it took some dedication to research all that - a person has to be a little obsessive to pioneer things that other people take for granted does this mean regular struts/shocks can be re-tooled? that could open a ton of options for the horrible roads over here -
those two 10mm bolts down by the firewall, under the pedals on the inside, don't necessarily have to come out, they just hold a little collar, (dust shield?) it'll come with the column I took one set out before I realized they could stay you might take the two 14mm nuts off your column, lower it, remove the upper and lower trim pieces and look at your column lock, maybe you'll get lucky and it's something dumb that can be worked around for now
get some tubing, vacuum line, aquarium tubing whatever you can slip over the bleed fitting (I stretch aquarium tubing with a philips until I can just slip it onto the bulb on the bleed screw) find a clean container with a lid, peanut butter jar, crystal light can - whatever poke a hole in the lid so the tube can slide to the bottom and won't pull out of the container place it by the wheel to bleed, pour a little clean brake fluid in the bottom so the tube is submerged in the jar open the bleeder, (not too far) slip the tube on the end go pump your brakes, watch the reservoir level, keep an eye on the jar by the wheel the fluid in the jar won't let air come back in the line - one man bleeder when you have the big air out, leave the tubing on the fitting and tighten the bleed screw just enough to let it leak a bit - for the last pumps on the pedal - get out quickly and go straight to the fitting and tighten it - if there is still fluid standing in the line you know that it didn't let any air back in to the caliper/cylinder have fun, if nothing else, you double check them when you have a pump monkey later
1989 coupe to Brat project
Txakura replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
LMAO -
I'm so sorry. brake lock = brain lock for so many idiots
takes OCD to all new heights - but by posting it, everyone can benefit from his hard work - proves it's possible, and shows the way to recreate the results - well done not sure why the disdain for nitrogen, been used in aircraft struts for over 60 years -
hover powered radar absorbent carbon fiber with a nuclear power cell
Man that sux, I lost a Mach 1 Mustang that way... you okay? passengers okay?
cool, thanks guys, seems to me there should be some 'old school' hot rodding work that would help me out the debate I'm having is a silly one, the EJ22 is the easy choice... but I kind of want something a little over the top as far as the ea82 n/a 1.8, after so many 100's of thousands of miles of service in more than one car I'm just curious about what would make it mo' better the solution is to have more than one car, ha ha
that looks tough! cool idea to show 1 pic from each year, nice Brat!
I changed my column by myself in about half an hour. Just get one from a yard.
How far did they go and what did it accomplish?
I find wrapping my head in tin foil cuts down on some of the noise from "the others" Stickers are good, as lots of Pinto owners discovered with 'Holley' and 'Edelbrock', but for my Loyale I found XT seats really add to the hp and torque, at least 5% think my mileage went up too
essentially the same thing, the problem is that there is no way to know until you get it off, HOW to get it off - that manual is worthless, you can't figure out the ratchet mechanism until it's already off the first time I pulled both I played hell with that OOL lip holding the shoes, the irony is that if I'd gone to the brake that was still good, it would have come off easier and shown me how to take apart the screwed up one... but I started on the one that was the problem - hindsight the second time I went in to them was to replace them with rear disc - that's when I came up with the 'hack technique' of just blowing away the pins and unbolting the whole mess and letting it fall off in a pile - but the pins are cheap, and it doesn't really hurt the cylinder or anything you'd like to re-use the pins can be cut with dikes from the back side, the whole mess off in 5 minutes (depending on the spline corrosion) glad you got it, turning the pin to pop it out of it's cup is a good idea
my car is already obnoxious with it's understeer, if I lift it, it's going to get worse?
^^^ my car is already obnoxious with it's understeer, if I lift it, it's going to get worse?
Chasing oil leaks on my second EA82 engine has me thinking I may go get my original one back and put it on the stand as a 'spare'. At least that one didn't leak anyone coined the term grEAsy82 yet? I am heading for an EJ conversion, the 'second' engine is supposed to be my low cost 'interim' engine so I can drive until the day I have something EJ to go in money and time spent on the grEAsy82's detracts me from the goal, mmmm k that being said, has anyone done a serious head massage on the EA82 TBI heads? was there ANY gain in power or delivery to be had? part of me wants to take my time cleaning up my old engine, essentially an overhaul, kind of a labor of love thing - part of me says that's dumb if you're just going to change it out in the next 12 months but then, none of this is really rational to begin with so what difference does it make what I do your thoughts?
hey, move the wiper up top! that'd be cool, out of the way of stuff and maybe even in your line of sight more...
