Txakura
Everything posted by Txakura
  1. roger, going to check the ecu itself, green connectors are not, uh, connected however, my cel has been sending me morris code that matches the description of the ecu signal, think it may be a 1990 spfi thing "90 models - Trouble codes on the Justy are viewed on the Oxygen Moniter light, all other models the codes can be viewed on either the Oxygen Moniter light or the MIL (check engine light)." this is a loyale rs so i'm assuming it falls under 'all other models' but no day is complete without sticking my head under the dashboard and practicing inverted yoga
  2. oh yes, lots of code posts, cel light confuses the hell out of me... not sure what it's trying to tell me - will look at ecu for giggles
  3. something isn't right, it has "no choke", maybe the iac's aren't quite right after all, but is there anything else in those 20 or so greasy widgets, dashpots, thing-a-ma-jigs and wiry bits that can make the car run as if it had "no choke"? anyone? buehler? buehler? anyone got a reader i can borrow, the dealer wants $80 just to hook the car to the diagnostic machine
  4. get a new turn signal blinker from the auto store and look for the same one behind the fuse panel and switch it out, cheap part too
  5. hmm slightly puzzled, acts like iac is bad -(unplugging iac makes no change hot or cold engine) i had an extra , cleaned it and put it on got voltage at connector to iac, resistence is within spec, applying voltage to iac i can see the plunger moving and hear the solenoid click cel comes on cold, goes away warm, car idles warm - not normally, slightly rough and under speed, but idles now what?
  6. had to look these up, this is the gl-5 spec without the friction modifier for lsd difs? for $45 a gallon? (my loyale pt awd takes 3.5 quarts in the gearbox)
  7. when my motorcycle was new it was tight and I was loose unless it starts happening all the time I'd let it go, I can't figure out if the switches being loose would let the pedal vibrate it off or if the switches being too tight would let minor movement disengage it
  8. I thought that sounded pretty good, I'd leave it the way it is, the cut out would probably make more hassle than it's worth
  9. sometimes when it gets below zero, you HAVE to take some of the load off the starter/battery - pushing in the clutch disengages the transmission jello from the engine jello and has made the dif between starting and not starting on several occaisions for me - never had abnormal throw out bearing issues from it - we have the same problem here as the original author, arctic air can come down unchecked through Canada and surprise us with temps as low as -38 (two years ago) we have also had -42, and -46 mornings, this year was weak - we only saw one -11 morning
  10. my car pulls forward about two feet also, the trick around here is to hold in your clutch for a while until the engine is running smoothly in fast idle and let it out - also helps to push in the clutch when you start it up other than needing two hands to shift into 1st, once i'm rolling it isn't a problem for the gearbox to warm up - i just drive at a low speed for the first few minutes in second and let it warm sounds like I'll be trying the redline product when the outdoor temp gets up to working temperature
  11. i just keep watching this over and over, it just sounds so unlike anything else, i sent a link to some of my gear head friends - I'm sure they'll get a kick out of it too wouldn't it just make you cry to have your audi, porsche or other smug mobile pasted by some guy in a subaru wagon? i love it
  12. I was an aircraft mech myself, i like the ac 43.13 wire ref you posted
  13. 2.4 mm = .094", 12 gauge non galvanized like coxy said is slightly heavier at .104" so .080" is a little too thin, i'll have to get some scrap and see if i can work with 12 does sheet steel come in different hardnesses? what's automotive? I'm only familiar with aircraft aluminum and steel (301 cres, 1/4. and 1/2 hard) mmm I have some scrap titanium
  14. i kind of like the Mad Max belts, power hump? show 'em off!
  15. are you sure we're not related, this sounds like something that would happen to me
  16. good stuff coxy, I had wondered if triangulating the strut braces might be a good idea to limit movement fore and aft, had even thought of a plate on the firewall to attach the struts to... chasing stress points can get kind of interesting I had also thought of a rear brace, but never thought to mount it to the floor, that's a great idea i'm glad you put some hard numbers in too, the material thickness had me puzzled as I haven't worked in steel or in gauges I wasn't sure what to use... I had been leaning towards .080" as the minimum doubler thickness and whatever that translated to in steel 'gauges' if I've offended anyone by semi-hijacking this thread... well, sorry. this is something I've been interested in for handling improvement and the door seemed open regards all, and 'g'day' to coxy
  17. that kind of sounds like the time I had a cv joint go bad very quickly, it went from a light ticking noise in parking lots to completely undriveable in two days the thing that was kind of wild was that it would leap/jump/pull to the right but it was the left side that was gone
  18. I kind of like the fact that a fair amount of folks here don't seem to feel house numbers are important... makes deliveries really interesting if i had mo' money I think I'd go a bit further out, just something on a rural road - you know, the kind of place where you could shoot off your deck during deer season and no one would complain
  19. That's why God gave it dual 19 gallon tanks! So you only had to fill up every other day! I am agreeing with coxy, an RX would have a strong value for me - not just in terms of money. Unfortunately, RX or not, it's a non running used car with a broken turbo. $100 and I'll take it off your hands type deal... I'd really like the running gear from the transmission to the rear wheels, if the body is super clean I'd consider replacing the engine, just my ideas for my situation. send me a pm if you want, I'd like to chat, and coxy; g'day
  20. that sounds fantastic, i ran it through my 5.1 with the sub turned up, absolutely great car, very clean and understated - till you open it up
  21. i put xt6 seats in my 1990 Loyale, the front two bolt holes line right up, the xt track has a hole to use for the existing seatbelt bolt, (I used a longer bolt, large area washers and a bushing - that kept the seat belt in the same place and secured the third hole in the track) the fourth hole, near the door frame required a longer bolt (8mm x 85mm) and a spacer the seats are lower to the floor than the stock ea82 seats but the driver is height adjustable and has a 4 way lumbar support and they add 5% more horsepower too
  22. i'll trade an '82 F-250 XLT for it let the bidding begin!
  23. Hello, bratman dropped your name as someone who may have some vacuum bagging and composite experience - can I pick your brain?
