tuner-auto
Everything posted by tuner-auto
Havent had a chance to test the wires according to Cougars instructions but I did manage to talk with the last mechanic to work on the subaie before it was trailered to me. Here is what he said he did ..... Replaced coil pack Replaced ignitor Replaced ECU tested coil to ignitor wires - ok tested ignitor to ecu wires - ok test fire coil pack - ok test ohms to knock sensor - ok test ohms to new crank sensor - ok test ohms to new cam sensor - ok test run with cam sensor disconnected - no run test run with crank sensor disconnected - no run test run with knock sensor diconnected - no run test run with MAF disconnected - CEL on runs bad Flash ECM - Runs OK now . Now after he flashed the ECM the guy I bought it from said it ran good for about a week then went back to running like I have it now. How do you flash a ECM ? Thanx
I think my meter may need a new battery then as I have tried using all the different Ohm settings at it sits at 1 . When I touch the wires you have suggested , I get no reading change on the meter. Sorry for this lack of knowledge but with a bit of patience I will understand this multimeter usage and be better for it . Thanx
Well here is where it gets to a real learning experience. Im not well versed in electrical and I never learned how to use a Multimeter . I have a Cen-Tech Digital multimeter . I have it set at Ohms at 200 The readout says 1 on the digital display I disconnected the coil and the ignitor and connected the leads to the blue wire and the other to the red wire. I get no reading on my multimeter. It stays at 1 . Thanx in advance for the electrical leasson Im going to get when this is all done
Picked up a 92 Subaru Legacy 2.2 5MT with 250k miles for $159 . Ran horribly but ran. Did a complete tune up with..... New plugs , wires , fuel filter , PCV , Air No change Checked for spark at coil and only 1 and 2 are arc ing from the coil to plug wires. Nothing on 3 and 4 . Swapped out coil for known good coil = no change - still no spark Swapped out Ignitor for known good ignitor = no change - still no spark Whats next ? Car starts right up and runs , just only on 1 and 2 cylinder. Thanx
