ettev
About ettev
  • Birthday 10/15/1963
Contact Methods
  • Website URL
    http://
  • Location
    Pottsville, PA
  • Interests
    cars, motorcycles
  • Occupation
    Construction Manager
  • Ezboard Name
    ettev
  • Vehicles
    Two 1985 Brats, '84 Wagon
Recent Profile Visitors
2218 profile views
ettev's Achievements
Subaru Fanatic!
Subaru Fanatic! (6/11)
11
  1. Is there a write up on rebuilding anywhere?
  2. Talked to NAPA yesterday........no good........out of stock nationally,
  3. Looking for a new/remanufactured set of calipers for my ‘85 Brat. Every source I’ve tried is saying out of stock, as is the supplier. Does anyone have a source for them? Also, what would be the correct part number of the aftermarket source you may have?
  4. Are they Gen 2 Brat’s a single-key vehicle? Same key for doors, glove box and ignition or do they have a different key for ignition?
  5. Nope, no braking at all using the pedal without getting the engine revs up over 3,000 RPM or so. Booster vacuum leaking down internally? Maybe bad rubber brake hoses?
  6. OK, strange situation. My '85 Brat sat for a few months. When I finally got into it again the brake pedal went straight to the floor. No signs of leakage anywhere from brake lines, caliper or wheel cylinders. No wetness on the inside of the wheels, no puddles on the ground anywhere. When I rev the engine pretty high I have a firm/normal brake pedal. When I let it return to idle the brake pedal goes stright to the floor. When I hit the brake pedal at idle the engine stumbles and wants to stall. Otherwise when driving around a nerby parking lot or idling the engine performs as it should.....until I hit the brake pedal then it wants to stall. I've replaced the master cylinder with a new one.....same result. I then replaced the hose and check valve from the intake port to the booster.....no change. I bled all 4 corners.....no change in symptoms. Am I looking at a bad power booster canister that may be malfunctioning internally? Could the new master cylinder I installed also be bad right out of the box? This one has me stumped. Given that the motor runs and idles fine I'm kind of ruling out vacuum leaks at the manifold. There are only a fixed number of things it could be so I'm just trying to see what the concensus says before I attack it again. I need to add that all of the emissions stuff is long gone from this Brat and I'm running a 32/36 DGEV Weber. This thing ran perfect before I parked it for the summer. Any suggestions would be appreciated.
  7. The car is an automatic-to-manual conversion but he's had it almost 3 years and this problem only started about 3 or 4 months ago. Biggest question...is it safe to drive? Also, what damage to the vehicle is he doing by continuing to drive it?
  8. Tires all brand new Goodyear, matching size. Mileage around 150K. Where is the fluid fill for the center diff? I'll dump a small bottle of GM Limited Slip Diff Additive in it. Works wonders in the new vette tranny's with shifting issues.
  9. Only when driven for a while and hot my kids 2001 RS has a horrible issue with binding and almost hanging up on a hard turn. CV joint? Low lube fluid someplace? Differential? It's a manual transmission 2-door.
  10. Zero pedal until the engine RPM's are up.
  11. I was thinking booster myself. Usually when a MC goes it works or it doesn't. Anyone else?
  12. Diagnose this: 85 Brat, power brakes. Not brake pedal either with vehicle off or with engine running UNLESS I get the engine RPM's up around 3000 at which time I get a firm pedal. No evidence of leaks in brake lining, calipers, wheel cylinders or at master cylinder or booster. Vacuum hose LOOKS good from manifold to booster. There is a small metal check valve at the midpoint of the manifold-to-booster hose. What's the culprit? Just trying to save time in troubleshooting.
  13. Good evening, I saw the work you did on that white Brat. Simply amazing. I just picked up a black 84 (my second Brat) that's in comparable shape - esp the bed and wheel wells. My question is about how much do you think it cost you to bring it up to shape (not counting the extra bits)? And if someone were to pay someone to do it about how much do you think it would cost? Thanks, Brendan Berry.
