Hello everyone,
Maybe someone can lead me in the right direction with this complicated mess. Its a long thread but see if you can give me some advice.
I just replace the t-belt and water pump. Since then the car started to overheat going up hill or on the highway, if I drove it for more than a half hour. I thought I might have done something wrong so I took it to my mechanic. He decided to change the t-stat since I didn't replace it. left the garage and I had the same problem. I took it back and he check the timing belt. He told me I was off by a couple teeth so he corrected the timing. Don't know if that was true since the car ran fine but I took his word for it. I ended up going for a long drive and the temp gage began to incline 3/4 of the way. I ended up calling him up and he said it must be the head gasket. Prior of this whole mess I did have an external leak at 64,000 miles which I fixed (if you want to say it was fixed) by putting in stop a leak. I wanted to make sure that it was the head gasket so I took it to the dealer. The dealer said the head gasket was leaking and wanted the radiator sent out to get flushed and replace the gasket for $2000. Oh! by the way. The car is an automatic with 124000 miles. Also, it take only 5 minutes for the temp to reach the half way mark. Is that normal?
Here is my question(s).
If it is the head gasket would that cause the car to overheat (3/4 way) only driving it on the highway for more than an hour? If so, do I have to pull the motor in order to replace the head gasket? Any insight will be greatly appreciated.
