Everything posted by Markus56
what would you have to do to fit these on a 91 legacy sedan? http://www.discountedwheelwarehouse.com/Store_Detail.cfm?ID=216405&InfoID=4278&ShowLarge=True&SnipID=4440 [url=http://www.discountedwheelwarehouse.com/Store_Detail.cfm?ID=216405&InfoID=4278&ShowLarge=True&SnipID=4440][/url]
2.2 head swap
Markus56 replied to Green's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
hate to say it, but it sounds like a timing issue http://www.lovehorsepower.com/SubaruDocs/TimingWaterPump.htm -
Just want to put this out there, leaking R-12 into the atmosphere IS A FEDERAL OFFENSE punishable by a $25000 FINE and it is ILLEGAL to put refrigerant into a A/C system that is known to leak. This is the ONE time you NEED to go an auto shop and have it PROFESSIONALLY fixed. You MUST be Section 609 certified to work on A/C systems.
2.2 head swap
Check for spark. I'm having the same issue, maybe we can help each other out. -
fuses are fine, found a vacuum hose under the intake i forgot about. put it back in and took a good look under there for any other stuff. re-checked the connectors and traced the wiring harness, its all good. I'm at a loss. dont know anyone in the area who has worked on these enough, i'll try to borrow a spark tester. Is there something that wont let the motor start if it is unplugged?
I timed it off the marks on the outside of the cam gears, the downside is, i have removed the timing belt covers, so i am eyeballing up and down, and using the marks that are on the belt itself. there is a possibility that the driver side cam is a tooth off. i will double check. I am a little disappointed with myself, because i timed an EJ25 perfectly the first time
If ya had an extra $500...
Markus56 replied to TRAVIS75's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 engine swaps are overrated. regardless of what the everyone says (GD), the EA82 is more than adequate for wheeling. and driving down the freeway with 235/75/R15's (30's) -
Brush guard taken from a Isuzu pickup and welded to a piece of channel, which is attached to 2x2 steel bolted to the stock bumper mount
reused the bolts, but used the gaskets i had. They were sold by fel-pro, but they had the FHI emblem embossed on them. this needs to be researched if fel-pro repackages FHI gaskets next question for the board: torque specs say to torque bolts 1 & 2 to 21 ft lbs and 3-6 to 11 ft lbs. did that. then to torque bolts 80-90 degrees. is that done by guessing? i know there is a degree spec torque wrench, but i dont have one. What should i do? eyeball it?
thats like a 10 speed bicycle (at's) versus a 500cc dirtbike (SS's)
