applegump
Everything posted by applegump
If memory serves, according to Chilton's, all you do is open the drain plug on the radiator, the "burp" valve on top of the radiator , and the drain plugs on the bottom of the engine. Then you add water until only clear water comes out everywhere. Then you let it drain, close everything up and refill.
I've re-looked at everything and there is no sign of external leak. It can't be the turbo, cause I dont have one . I checked the radiator for a hairline crack but didn't see any. About the air trapped, it is a very small possibilty because I have added more coolant than the capacity of the system. The oil level hasn't risen to my knowledge and the oil isnt muddy. I'd now like to check the system under pressure. How is this done? What equipment do you need? If there is still no leak under presssure, then it's an intake manifold leak or a headgasekt leak, is that for sure or is there another possibility?
I recently replaced the thermostat due to failure, now I seem to be loosing coolant but cannot find any external signs of leakage, neither can my mechanic. I fill everything up (including expansion tank) but after a week (250 miles) the expansion tank is practically empty and the radiator is down a few inches. Anyone know what the cause/cure is? Thanks
