SoobrDad02
Location
Richmond
Interests
My kids, my wife, my car!
Occupation
Student/Full-time dad
Biography
First-time Soob owner
Vehicles
1991 Legacy L wagon
SoobrDad02's Achievements
Advanced Member (3/11)
10
FOR THE LOVE OF ALL THINGS HOLY, YOU ABSOLUTELY, POSITIVELY MUST MAKE SURE THAT THE TORQUE CONVERTER IS SEATED!!!! I've got a first generation Legacy wagon holding down the driveway currently because I have yet to locate a transmission with decent mileage to replace the one that was destroyed when I didn't ensure that my torque converter was re-seated before final install.
Hey everyone, I just wanted to find out if I could use a '99 4EAT n/a transmission to replace the currently non-working one in my '91 4EAT n/a transmission. I need to know if it'll be a direct bolt-up, or if I'll need additional parts to make it work. I don't know the gear ratio on the '99 yet and wanted to know if this would be a plausible swap. Any help would be GREATLY appreciated, THANKS!!!
I've re-pulled the engine, re-seated the torque converter and put her all back together. Only thing is when I start her up and put her in gear, she goes nowhere. I give her gas and the engine just spins, no engagement of gears at all. I'm guessing that I toasted the transmission when I bolted the engine to the transmission the first time with the torque converter incorrectly seated. Grrrrr.....
Well, here's the latest... I pulled the first flexplate-to-torque converter bolt and managed to muscle the crank enough (with the help of a breaker-bar) to remove the remaining bolts. Now that it's un-bolted I can turn the crank easily (it seems to encounter one "tight spot" at the end of a rotation). So does this mean that it was an un-seated torque converter all along, and if it was, will I be able to pull the engine again, re-seat the torque converter and put it all back together without worry?
Wanted to ask the pro's on this board for some advice before I decide to set my car on fire... I drive a 1991 Subaru Legacy wagon 2.2 n/a 4EAT, and I just pulled the engine, replaced the flexplate, and re-installed everything only to find that when I try to start it all it does is "click" audibly once and then nothing. I've put a breaker bar on the crank and tried to turn it manually and I can't get it to budge in the least. I pulled all 4 spark plugs and tried again to turn it over manually, and still...nothing. I'm not too sure where to go from here and I don't want to get frustrated and mess anything up anymore than I may have already. Any ideas would be greatly appreciated, thanks.
Installed a NEW OEM Coolant Temp Sensor...no change. Picked up 2 j/y IACV's today, installed the first one and took it for a test drive...no change. I got back to the house and tried pulling codes and found nothing either by using the green connectors or d-check mode. I unhooked the battery before calling it a night in the hopes that re-setting the system will magically fix everything. in the case that it doesn't though, I'll install the other one and see how it goes. I have spare MAF's sitting around and I'll try installing one of those as well. I DO want to know though, if I install the sensor that sits in the intake, do I also replace the unit that the wires run to that's attached to the fender? Also, what's the recommended technique for cleaning a used IACV? This car's gonna be the end of me...
Just updating... Spent some time(and an ENTIRE can of carb cleaner) looking for the vacuum leak the other day and still couldn't find anything. Removed the airbox/intake tube assembly to allow for further visual inspection of vacuum lines and couldn't see diddly. I am also experiencing a very random/rare issue with the throttle. While attempting to pass in traffic the other day, I found out that she'd get to 3,000-3,500 RPM's and then just kind of top out without gaining any speed. ideas as to what could be causing this? I'm thinking that they're connected, but not sure... :-\
I'll try the carb cleaner, and as for water in the tank, I did think of that and have added some of the "super" HEET gas treatment at my last two fill-ups to no avail. As an aside, I do want to say thanks for all of the great advice I've gotten on this forum, everyone here has proven EXTREMELY helpful whenever I've posted with a question/problem, so THANKS EVERYONE!!!
