coxy
5
coxy last won the day on July 20 2024
coxy had the most liked content!
Location
Sydney Australia
Interests
Bikes Rallying Photography Diving
Occupation
Automotive technician/Bike Mechanic/Engine and CNC machinist
Biography
Worked in MX ,Rally preperation,CNC Machining,Engine and Powerplant conversions in cars bikes and Boats
Vehicles
I Love My Subaru Brumby
Recent Profile Visitors
coxy's Achievements
Subaru Fanatic! (6/11)
80
Firstly is it a solid lifter engine or a hydraulic lifter model, I suugest you check the stickies at the top of the old gen discussion to make sure which one you may have. May being the operative word as people can and do mix and match componets sometines when overhauling an engine you likely do not know the history of. I suggest you trial fit the pushrods bewfore you fit the rocker gear to make sure the cam is in the right position with all valves closed or on the rock between one opening and one closing to make sure they do not get bent again, Check, Check and check again and tighten the rocker gear slowly and evenly after making sure the pushrods are correctly located top and bottom.
We Post Our Grievances Here
coxy replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Only one gripe really they should have made the EA81T multi point injection engine as the standard non turbo late variant normally aspirated EA 81 and then punched it ourt with a stroker crank to 2 litres with MPFI for fitment into the Loyal and the Evil EA 82 should never have escaped the Lab. Imagine how good a flat six EA81 type engine with MPFI would have been and then to add some spice for the XT6 they could have been an XT8 with a flat 8 MPFI torque monster, So I guess the biggest complaint is Subaru went mainstream and started making Cookie Cutter specials like all the rest of them. -
Unlike other EA 81 vehicles the Turbo's used an early EA 82 Loyale type Power steer pump so look into one of those easier to find than an EA 81 MY turbo wagon one.
- 18 replies
- vacuum
- automatic transmission
(and 1 more)
Tagged with:
Leaking coolant from intake gasket?
coxy replied to LucasP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thirteen to sixteen foot pounds -
Try and find a catalogue that gives dimensions from either ARP or SPS and then look and see what you could make work. I have in the past modified a Nissan Z 18 Turbo to use Ford Windsor 289 bolts and used Toyota Supra ARB studs in a Drag Lancia Delta Integrale engine in a 1200 Datsun ute so anything is possible, though you may have to drill out the head bolt holes in the heads and block if the diameter is bigger. There will be something that will work just have to do the research.
EA81 4 Speed Dual Range Shifter Bushings PLEASE HELP
coxy replied to clantieri's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Last time I did mine they were in stock at Subaru, I would assume the same with higher stock levels in America, You just need to find a parts person who can read and still has the old paper parts manuals as I know they did not put the early stuff into the online computer listings though they do have the parts if you know the numbers, How frustrating. I have a pdf of the engine parts manual surely somewhere somebody has a copy of the parts book for the body and ancilliaries in pdf format to download. -
Spider Manifold: what's the advantage?
coxy replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I vaguely seem to remember the TPS may swing in opposite directions something to check possibly -
EJ plus its AWD box into std EA81 - tunnel mods ?
coxy replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In NSW with our RMS standards (yeah Right with the current mob of Pakistani Engineers at RMS who do not have a clue) the limit for self certification is a 15% increase in capacity which means an EJ 20 is self certified as long as no major modifications are needed. So considering physically a single cam EJ 18 or 20 can basically be bolted in with a little file work slotting mountings for the engine that satisfies the criteria for self certification and no engineers report required. May be different because of your penchant for running LPG however so check that aspect. -
You are not wrong there Jesek, Even the latest Oil spec reduces the ZDDP zinc phosphorus anti wear additive in engine oil under the latest standard so catalytic converter life is extended at the expense of engine life. That is why so many with high performance models such as Evo Lancers and WRX's have taken to using Motorcycle specific oils. They not only have higher anti wear additive packages than modern car specific oils but because the viscosity index improvers when seen under an electron microscope resemble a microscopic nylon clock spring that expands when heated thus thickening the oil and those things do not like living with gears such as the modern motorcycle engine contains because one oil does both engine and gearbox plus wet clutch duties they had to refine the base oil further to gain the heat resistant benefits normally supplied with cheaper VI packages that do not survive well in Motorcycle engines. The VI improvers often make their presence known when oils are not changed often enough as when you drain the oil a sludgy goop comes out first then thinner dirty black oil the sludgy goop is the mashed up VI nylon clock springs that get chewed up and coagulate in the bottom of the sump.
ej22 swap no spark on cylinders 1 and 2
coxy replied to Tye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Late model alternators are allmost all Internally regulated so if it is overcharging it is the alternator likely at fault. Modern alternators have a main power output connection usually bolted on and either a single or double wire plug, One wire supplies ignition power to excite the field coils to make it charge and the second wire is often a seven volt tap off the alternator windings to send the correct power supply to the instrument cluster. Maybe the volt gauge is reading high because instead of a seven volt input from the alternator it is seeing full alternator output volts, Thirteen plus five equals the eighteen you are seeing because trhe gauge is expecting to see seven volts so at full output it is getting fed five volts more than expected So if the alternator is running around thirteen volts which is normal after recovering from starter load then while it may be a little low it is not unusual, Add five volts which is the difference between a seven volt tap and a nominal twelve volts and that could well be the issue for the gauge reading high. measure at the Battery what the alternator is actually putting out. -
On further thought do not just trust a Multi Meter for voltage checks as I have seen them read Voltage OK but when you check with a Test Light the globe is dim showing that there is not enough current to take any load. Voltage and Amps are required to do any significant electrical work, Hence the globe by putting a load on things will add an extra check into the system to verify the circuit can actually work in real life situations.
Pre heat nah considering it will be a side drauht carb conversion I would look at something like a Mikuni Carb normally used on Harleys, Big enough,Jets available and considering engine characteristics probably not that far out of the ballpark as is for a good starting point. After all it would be a single barrel carb to replace a single barrel throttle body and just need an adapter plate and rubber manifold to make it work.
It may well not be the actual sender that is the problem but a bad earth or connection in the instrument cluster or between the sender and the dash something quite common as wiring ages over the years.\Generally it will be at the connectors or where they are crimped as the wiring on these older model cars is much heavier gauge than late model vehicles where cost cutting and supposed weight savings rule the roost. There will not be too many late model vehicles that will be saveable thirty odd years down the track.
1988 is now three years short of thirty years old, I would think that the first thing to make sure is working correctly is the ignition switch as is is a mechanical connection in the actual switch part on the back of the ignition barrell assembly cum steering lock unit. It is a simple unsrew to remove the actual electrical part and then check with an Ohm meter to make sure all is happening as it should there after all it is the major part with moving contacts that can and do wear or get dirty.
Pretty sweet wagon you found there and probably one of the most reliable long term vehicles you can own as well as versatile. Plenty of FWD models have been turned into four wheel drive variants and if doing such in the future make sure to use the later L series five speed out of a wagon as the RX turbo variants have only a 1.1 low range wheras the proper wagon is a 1.59 low range ratio. It should still be being an MY, Torsion bar in the rear that is why you cannot see any springs only shocks. As for the front springs the 4WD models do come stock with adjustable height struts a much better option to swap in. The Oil pump is easy to reseal with new "O" rings, do that first and give it a good clean then see if there are any other leaks as a leaking oil pump will run back over other areas making a mess and you may well find that is the only major leak. Finally welcome to the board enjoy the experience all on here are very helpful.
- 1 reply
- 1
