windshield wiper issue
zedhead replied to roger1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWorn bushings?
TQ Came Off During Engine Removal - Need Help
zedhead replied to subaruUser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, if the pump was damaged, there's no real way of telling until the engine is started. I suppose you could pull the tranny and inspect things. But, your prolly better off just bolting it back together and testing. I'd install the shafts, and then align the cogs on the TC to the shaft. It might take quite a bit of figiting to get everything aligned, and seated properly. The TC should be behind the mating surface of the trans/eng 1/8-/1/4" You can use a straight edge across the trans mouting surface to check. Climb into the engine compartment and sit on the crossmember to get every thing aligned.
02 LEgacy 2.5 SOHC: TB, WP, seals; Book Time?
zedhead replied to MilesFox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI sure hope that your not working outside, in Wi.? Brrr.. If you are, add 2 hrs for Warming Hands!
Trying to decide whether the transmission is bad-picture of oil
zedhead replied to murfmv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles? Is the input shaft worn where the seal rides?
Engine Work with Pics
zedhead replied to okamikai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLets hope that the wrist pin didn't score/ ruin the liner!
Extreme Cold Weather Starting Problem
zedhead replied to IdiotSavant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFWIW, buying a bottle of heet for every tank is a waste of money. In the first place, all that Heet is, is Isopropal Alchohol. You could go to walmart and buy a quart of it for about the same price as a pint of heet. Add one or two cap fulls to a tank would be just as effective as a bottle of heet. Secondly, You should not need any heet/alcohol in your fuel. The refineries have already included it in your fuel. The winter blended fuel is so full of additives, that it effects mileage. If you buy your fuel from a high volume station. You should never have a problem with water in your fuel.
zedhead replied to subaruUser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure, they wear out. Also, these are extenuated circumstances. $5.00 is cheap insurance for doing a job twice.
Problem with my first subaru. I'm scared HELP!
zedhead replied to Pathfinder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck/clean the IAC
zedhead replied to subaruUser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd replace the tranny front seal. $5.00 seal vs pulling it all apart again if it leaks???
Easiest way to test fans?
zedhead replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth of my Suby's run with the guage showing half way.
Front end problems--alternative to $750 bill?
zedhead replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs far as the wheel bearing goes. I usually remove the knuckle/hub at home. Then take it somewhere that has a hydaulic press (and knows how to use it) have them press the old out/new in. IIRC, around $50 per
3rd gen LEG and BAJA hoods/headlights differences?
zedhead replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will fit. There are a couple of minor differences. The horns on the later hood are a little shorter, and the windshield washer squirters are a little closer together. Nothing that most people would even notice. So, Yes. I'd say the rad support is off. Around $60 for a new one. You'd need a spot weld remover, and a welder to attach it.
Gas additives
zedhead replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel additives are a muilti million dollar scam. You can use them, but show Me a study that conclusively shows any improvement in a properly maintained engine. There are already so many cleaning agents in the fuel You buy.... more is not always better.
Bearings for front cv shafts
zedhead replied to Kurt17k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA Drive Shaft is a tricky thing to get rebuilt properly. I bought one from a local rebuild shop, and it was a POS. Vibrated from the get go. http://www.ccrengines.com/mwe/index.html
Subaru: top reselling car next to BMW
zedhead replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWeird, over on the other site it says Suby, and Honda are the top resale autos
zedhead
