fleming442
Location
The Forest
Interests
Oldsmobiles
Occupation
Cable Slicer
Vehicles
02 OBW, 2.5/auto slug
fleming442's Achievements
Advanced Member (3/11)
10
There is a HUGE thread about this on outback.com. I remember seeing a reply that said the rear suspension changes caster & camber with travel. I have an 02 OBW, and have had her cranked up in the triple digits. It was very stable, but then again, the problem seems to be '05 & up. Tires make all the difference in the world. I had some cheesy Firehawk GTII's with alot of wear put me off the road because they hydro'd. I got some Bridgestone Grid 0019's mainly because I like the aggressive tread pattern. So far they have made it up my driveway when my 2500HD had trouble in 4WD!
So, is this bunch just too cheap, or does noone have aftermarket wheels? I have a bent factory on my 02 OBW, and thought it would be a good time to jazz it up a little. After doing a search on here, all I come up with is: the factories have a 56.1mm center bore, a 48-55mm offset, and a 5x100 bolt pattern. I see multiple mentions of the aftermarkets being mostly 35mm offset, and implications of premature bearing wear. Seriously? I just can't see 10-15mm making that much of a difference, other than it looking screwy for sticking out too far. I'm not looking to break the bank, but I would like something other than the boring factories. So, let me see some pics; what have you done?
So, I get in the car to go to work (37mi. one way), and I noticed a slight thumping. It sounded like a flatspotted tire, and I have a slow leak. So, I figured I just needed some air. I stop at a couple of places in my hometown before I head down the road. They are all $.75 for air (what a rip!), and all out of service. Go figure. I'll take my chances. I made it down to work uneventfully, but the trip home was not so much. The thumping had gotten louder with a noticeable vibration to go along with it. It got to the point I was doing 50 in the slow lane with the hazards on, hoping I could just get it home. I was thinking of everything: bad tierod end(s)- could end up real bad if it broke, ball joint- same dismal scenario, steering rack- even worse. Luckily, I got it home. I didn't really have time to go in depth, but curiosity got the best of me. I gave it a couple of good shoves with my boot. Then, I noticed a gap between the rim and rotor. Now, I had just rotated the tires 2 weeks prior, and I have been tinkering with cars for the better part of 20yrs. I have never had lugnuts come loose. I hit them lightly with an impact then torqued them to 80 ft/lb. I remember it distinctly. The only solution I could come up with is: Some S.O.B. tried to steal my freakin' wheel!!!!! 4/5 of the lugnuts were loose; the only one tight was the lock. Sorry for the long post, but heed it as fair warning. Some crackhead is out there trying to get your stuff! My question is: when I do dive in, aside from the obvious (egged out holes in the rim, mangled stud threads), what else should I check (Wheel bearing, tierod ends, etc.)?
I guess it really depends on how handy you are....... I recently got freaked out over my exhaust (there's a thread somewhere). It turned out that the gasket had blown out where the mid-pipe meets the muffler. I found some Bosal parts from NOPI, a Borla at Jeg's , an ebay header, and a cat pipe from NAPA would set me back about a G whether I went Bosal or Borla for the catback. So, being the cheapa$$ that I am, I got a gasket from Carquest for about $5. It turned out to be the wrong one. Luckily, Advance had the right one. The studs were rusted so bad that I couldn't even see the flats of the hex, so they had to go. After much drilling and grinding, I had 2 holes that I could get bolts through. Guess what? The flange was rotted well enough that the gasket wouldn't seal. So, off to Advance I go again. This time I bought the last 2 gaskets they had. I sandwiched all 3 together with some red rtv in between, and "WALA"- no more leak for about $20! It did take the better part of the afternoon, though, and I have a fairly well equipped shop. I wouldn't reccomend the apt. parking lot. This was an '02 OBW 2.5/auto w/ 160k mi.
Well, the way I figure it, the dealer is absolutely out of the question, as are run of the mill muffler shops. I went through that on a Civic, and the crap only lasted 6mo. I have used NAPA stuff in the past, and it is very close to OEM. I have a Magnaflow on my truck; it's SS and very nice. However, I find no listings for OBWs. I would like to go Borla, but I have to weigh out the life of the car vs. the expense of the exhaust. As mentioned before, I HATE doing exhaust work, so my plan is to cut everything off and start anew. I've seen a thread or 2 about the epay headers, and the fit seems to be good.
So, here's the scoop. I need a new muffler. Some may recall my cat issues awhile back. I hate doing exhaust work, and the whole system is sketchy anyhow. I plan on replacing everything underneath. Has anyone used the Borla 14885? Trust me, I'm not buying it unless I can get it for wholesale. The rest of the system was going to consist of the epay header (which I just checked and is no longer there), new 02 sensors, and a NAPA cat pipe. I am open to suggestions, and am curious about your experiences.
