Everything posted by tractor pole
Snow pics thread. . .
tractor pole replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
as promised a better one... -
As most on here will tell you, the search function is your best bet... The linkage is different at least for the 4wd shifter, that is all that I can tell contribute.
IIRC lug nut torque is 74ft/lbs at least that's whats called out in the FSM M12 range should be 70-80 ft/lbs
5MT D/R difficult to get out of 4hi
tractor pole replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I looked today for the ID tag but it was unreadable, but I think it is working as advertised. Since I did not have an owners manual that covered the D/R transmission I assumed it worked like any other "shift on the fly" 4wd, but I know better now. -
so I think all is ok, I tried it today on snow covered road and noticeably easier to shift. thanks for all the input, I think a crisis has been averted. Ben -
crappy cell phone pics, first pics on here of the finished five lug swap. I will take some better ones tomorrow. -
I hadn't realized that it would bind up that easily... I will have to just get used to it. thanks for the input everyone. I am still curious if the JDM transmission actually has a different final drive ratio than 3.90. -
I should also add that it feels like a brake is dragging when "bound up". once back in fwd it feels normal. -
it was on wet pavement , I know that's not the same as snow/ice or gravel. the diff ratio in the car is the original, 91 Loyale that came with a 3AT, 3.90 is what is on the tag. this is not the original trans, I swapped it from a 3AT so I do not have the owners manual since you couldn't get the Loyale with a D/R... Do you know what the JDM ratio is? I have looked and looked and all I can find is 3.90 for the PT D/R. -
the tires are all brand new 195/60-15. Driving in a straight line, yes. As I described in post #2 I can't see the linkage being out of adjustment, that is why I was thinking different ratios in the rear diff and trans. -
I guess I should add that when it is not running shifting from fwd to 4 hi and back is easy but it seems that after you have driven in 4hi it gets difficult. -
So I have been able to actually test the 4wd in my recently installed 5MT D/R and found that getting from 4hi to fwd is more difficult than I think it should be. once in 4hi it will shift to 4lo and back with no problem, the difficulty comes when you shift from 4 hi to fwd. I have tried all different scenarios: engine on, off. clutch in, out. rolling or stopped. the only way I can get it to go back to fwd is to roll slowly 2-3mph clutch in in neutral and force the lever down. it makes a loud banging noise when it disengages. I have only done this twice, I am trying to keep from damaging it. I am pretty sure that all 5mt D/R are a 3.90 final drive, the rear diff in my car is a 3.90. The trans has 23 spline axle shafts so i am 99% sure it is from a non-turbo car. Is it possible that a JDM trans (from japanese engines) could be a different ratio? thoughts? Ben
oh yeah, I meant just the EJ bolts won't fit. sorry bout that.
here is the answer, NO. the EJ bolts are completely different. I had to get them from the dealer, $11/ea
My new Project: Leone Turismo
tractor pole replied to Lukas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks like a rear fog light on the left side, would be a cool thing to have. -
My '92 Landcruiser: Safariwagon-II
tractor pole replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
Looking good! reading this makes me really want a FJ80!! OME lifts are very nice, looks like it was a pretty straight forward installation. can't wait to see what it looks like with the rear done as well. -
'88 EA82 FSM Wiring Section
tractor pole replied to TomRhere's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks like Dave beat me to it. -
I have a copy, but i wouldn't be able to get it scanned until late tonight or tomorrow morning. Ben -
1999 Phase II EJ22 into 1987 GL Wagon (carb)
tractor pole replied to kanurys's topic in Subaru Retrofitting
Very nice, I am planning on doing this swap down the road. thanks for putting up the time to make the spreadsheet. -
I must have overlooked this one. Thanks for the info. Ben
New clutch slips, how to float gears?
tractor pole replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think the pressure plate side of the clutch disk would hit the flywheel if you put it in backwards, from what I remember when I did the clutch in my EA two weeks ago... -
Welcome! More locals, cool!
I will keep that in mind, I haven't driven it too much(less than 5 miles) since I got it aligned. I am driving it to work today.
I was told that my steering rack was toast but I am not sure of it is because of the tie rods or just a bad rack.
