tractor pole
Everything posted by tractor pole
  1. I have the Yakima 1A towers on my wagon. If you have the plastic gutter trim you have to place tge tower over the b pillar and rear side windows so the windows don't hit when you close the door.
  2. It's engaged as soon as the lever is moved. The lo indicator should be there, I got a center piece of the instrument cluster from a s/r and d/r to swap over on my a/t instrument cluster and both had the lo indicator you just have to hook it up. Give me a day and I can dig up some wire diagrams for you. Take a bright flashlight and shine it on the center of your instrument cluster and you should be able to see the lo Ind.
  3. Just make sure you are on a loose surface when you test it out. The d/r like to bind up if you engage them on pavement even if it is wet. At least that has been my experience.
  4. I am not sure what part of seattle you are on but airport welding and exhaust in snohomish did my cat back and they were a fair price and really good work. Ben
  5. Http://www.infernofab.com has adapter plates also some very nice headers. Ben
  6. Most good automotive machine shops will be able to resurface it for $30-40. As long as it is not cracked or scorched too bad, I say resurface it, just make sure they machine the step properly.
  7. check this out... MilesFox has some great videos
  8. It's a really good feeling right after the first start. I really like how your wagon has turned out! Keep up the good work. Edit: bad grammar, auto correct.
  9. Did you swap it from an automatic? I did that it was the second best thing i have done to my wagon next to my ej swap.
  10. this is how I tow... I would have no problem towing under 1000lbs properly loaded with my wagon... however you have to consider that since the manufacturer has not set any limits and basically advises against it your insurance could possibly deny a claim if you are at fault in an accident that was towing induced (either improperly loaded, brake failure, etc...). So be careful even if you don't have full coverage the insurance company might try to deny your liability claim for exceeding mfg GVWR. I am not at all an insurance law expert, just my .02
  11. nice! good to hear that it was not harmed.
  12. look here http://www.ultimatesubaru.org/forum/showthread.php?t=130943
  13. I tried for hours and was not able to get the pedal box our with the steering column left in or even dropped down, save yourself the pain and just take it out.
  14. I have the same problem. Does anyone know the resistor values? So you could rebuild the resistor pack. Wait i just read tommba's post again... going to radio shack on the way to work.
  15. tractor pole
    Datsaru
    Nice M37! My friends is a radio truck version. the hard top is really cool too Ben
  16. tractor pole
    Datsaru
    Nice Power Wagon! recently I helped a friend of mine pull the motor in his M37 (the military version of that truck). I really would like to have one one day. I also agree that the stock loyale headlights are garbage.
  17. Merry Christmas! Already received some stuff for the wagon!! Ben
  18. so I have went to the practice of just using 4wd on snow or mud. dry/wet pavement still binds up and makes it difficult to get out of 4hi.
