About muffman
- Birthday 10/12/1979
Location
Tacoma
Vehicles
1996 Legacy L AWD Wagon
muffman's Achievements
Member (2/11)
10
There may be a ground somewhere in the circuit. Try putting the multimeter on the continuity setting (or resistance if it does not have continuity) and check between the positive connection for the bulbs and the ground. If the positive has continuity/no resistance with the ground, there is a short somewhere. ***You might take a look at the wiring to the radar detector to see if there it is causing the problem***
I bought a 91 awd legacy with 206k miles on it for $900. It ran fine (it did have a check engine light on for the evaporative system) until someone t-boned me and totaled it. Seems like a good deal, if it runs and drives good. I have never checked oil pressure, so I cannot help you there. I'd say if the light is off and it runs without excessive valve noise you are probably ok.
Oh, does that thing have mechanical fuel injection? Working on that was a nightmare for me. I was thinking the kind of fuel pressure regulator most electronic fuel injection has, the systems are pretty different. Please forgive my pointless rambling. Subarus do have a very bosch-like fuel injection, so the fuel pump might work.
I think that the fuel pressure regulator allows fuel to flow back to the tank when there is too much fuel pressure. There should be a feed on the fuel rail from a fuel filter, and that is where the fuel should come in. Fuel pressure regulators normally make your car run really rich when they stop working. I tried the diagnose/replace parts thing for a while on an early 80's volvo, it would be much cheaper to have a mechanic figure out the problem. It is really amazing how much easier stuff with obd/obdII is to diagnose.
You might think about using the all wheel drive setup from a civic wagovan, and maybe throwing an integra motor in it. I know that is not a subaru set up, but it might just be way less custom fabrication.
